Spotify
Posted by: Hal on 30 May 2016
Spotify drops out on UQ2. This is surprising as I have never had a streaming issue with Spotify, it has always been rock solid. Deleting and reloading Spotify app did not sort it out. UQ2 (on 4.4 fw) is hardwired to network.
Anyone experiencing the same glitch?
Posted on: 30 May 2016 by Jason
I started losing iRadio during the week which has previously been absolutely solid for months and months. I found I needed to restart my BT home hub (3).  I turned it off for 15 minutes, fired it back up again and let's all the lights settle, then everything has been solid ever since.  Turning your modem/router off for 10/15 minutes might help reset things again.  Might be worth a try.
Posted on: 31 May 2016 by Hal
I turned off everything and after 10 mins started in the order of fiber op modem-routers-switch-UQ2 and Apps last night. Same drop outs with Spotify. Interestingly, there was none with Tidal. Maybe it's something to do with the servers of Spotify.
Posted on: 31 May 2016 by Jason
Possibly could be a Spotify issue, but I'm afraid that's exhausted the extent of my IT knowledge on such things!
