System Combination
Posted by: Tham Kok Leong on 30 May 2016
Apparently, I have the following system components,
[1] CD5XS
[2] ND5XS
[3] DACV1
All this system components are connected to NAC202 with HICAPDR+NAPSC and NAP200 on PROAC D20R speaker system.
I wished to get some advice which method will produce best sound quality.
Option (1) CD5XS (digital output) ---> ND5XS  (digital output) ----> DACV1 (Analog output) ---> NAC202 ---> NAP200
Option (2) CD5XS (digital output)  and ND5XS (digital output) ----> DACV1 (Analog output) ---> NAC202 ---> NAP200
Option (3) CD5XS (analog output)  and ND5XS (analog output) ----> NAC202 ---> NAP200
The last option is to omit DACV1 as DAC decoder and use the respective system component internal DAC for digital signal processing.
Please advice. Thanks
KL Tham.
Posted on: 31 May 2016 by Michael Mccullough
The DAC v1 seems to be redundant in your system. I haven't compared the DAC V1's DAC to the ND5X's so not sure which would be better on the CD5x.
My guess is that it would be best to sell/trade the DAC V1 toward a NAPSC and Hicap for the 202 or a XP5XS for the ND5XS
Posted on: 31 May 2016 by hungryhalibut
As you have all the boxes, surely you can try the combinations for yourself. If it was me, I would swap the ND5 and the Dac for an NDX.
Posted on: 31 May 2016 by Chag...
Michael Mccullough posted:
Indeed. Alternatively or subsequently go S/H nDAC on ND5, then PSU on nDAC.
Chag -
Posted on: 01 June 2016 by hungryhalibut
Or you could sell the ND5xs, the V1, the 202, the Hicap and the napsc and get a 272.
Posted on: 01 June 2016 by oscarskeeper
Hungryhalibut posted:
This sounds like the glaringly obvious option to me.
OP - how come you ended up with all these bits of kit you seem to know nothing about?
Posted on: 01 June 2016 by dayjay
+1 providing you are happy streaming and don't need CDs playing
Posted on: 01 June 2016 by Tham Kok Leong
thanks guys for the inputs. It looks like DACV1 is not very helpful in my setup which I might consider of trade/sell it.  Maybe I can consider of replacing :-
[1] Trade in DACV1 with a nDAC
[2] Sell off DACV1 and use ND5XS internal DAC
Posted on: 02 June 2016 by hungryhalibut
dayjay posted:
I didn't suggest selling the CD player though...
Posted on: 02 June 2016 by feeling_zen
Or if box count is not an issue, keep the 202/200 but replace the CD5XS, ND5XS and V1 with an NDX.
Posted on: 02 June 2016 by Tham Kok Leong
My main source of musics are playing from CD and streaming from NAS therefore streamer and CD player still as my main component.
I only confuse whether an add on DACV1 will improve sound quality or not?  With advice given,  I am considering of disconnecting source devices to DACV1 instead go direct to NAC202. (let ND5XS and CD5XS internal DAC to do the processing).
With this, I keep DACV1 for other room setup by adding NAP100 to power my spare KEF LS50 speaker.
Posted on: 02 June 2016 by engjoo
dayjay posted:
+1 for replacing ND5XS, DACV1, NAC202 with 272.
Having the 272 would still allow you to keep your CD as a transport source.
Tham Kok Leong posted:
The DACV1 is really redundent. Yes place use it with a NAP100 elsewhere.
Again, you will get better results consolidating the ND5XS and NAC202 with the 272.
