Phono cards in a nac 42.5
Posted by: Garry on 01 June 2016
Hi everyone have just purchased a Nac 42.5 but it has moving coil boards in it.  Are  they changeable in this amp..I am not sure .??  . If so, what are the do's and do nots..??
Moderated Post
Posted on: 01 June 2016 by Richard Dane
Garry, yes the phono boards can be changed; NA322 MM, NA323 (S, K, or E/R) MC, NA326 Line, or NA328 "CD" boards can be used.
If you are looking for replacement boards, note that they are no longer available to buy new, however Naim dealers often take them in stock secondhand or have pairs of boards tucked away in drawers, so well worth having a ring round some dealers.  Otherwise, they are regularly available privately via the usual places online - however caveat emptor applies.  Try to find the latest type boards you can, so for MC boards that would be 323/5 and for MM, 322/4.
As for the do and don'ts, just be careful when you slide open the tray from the cover that you don't damage the fascia. Ensure any boards are firmly and properly located.
p.s. Please have a read of the forum rules, thanks.
Posted on: 02 June 2016 by Garry
Thank you Richard...Will try to source some 322/4 as I have the 323/5 boards...It is just that I like shure cartridges in my Thorens TD 150 turntable. The TP 30 arm is compliant with these MM type carts.
