Wich speakers with an entry level set-up?
Posted by: Michaudg on 04 June 2016
Hi. bonjour,
I am new in this forum and I am revamping everything...
I just upgraded to the following Components  : Naim FlatCap xx, Naim NAC 112x et Naim  NAP 155 XS (previously from a Crown DC 300 amp, Dayton Wright pre-amp and a pair of  IMF TLS 50 geriatric speakers, that is revealing of my age... ).
Therefore and I'm about to purchase either new or preowned Loudspeakers. I'm seeking a word of wisdom from this panel. I'm torned between thoses:
So, can you enlighten me a little more please?
"Respectfully yours".
Gilles from Montreal.
Posted on: 04 June 2016 by wenger2015
Hi and welcome to the forum....I'm personally not a fan of Harbeth,  others I'm sure will disagree, which is one thing you will find on the forum... lots of differing opinions.....i would definitely audition the neat motive 1, regarding the Acoustic Zen Adagio I can't comment having not ever heard them....would also suggest focal have an excellent range, as always best thing to do is have a short list and home audition and make your decision based on your own listening experience...
Posted on: 04 June 2016 by Michaudg
wenger2015 posted:
Thank you so much.
You must update on how you get on.....
Posted on: 04 June 2016 by Frank Abela
As you are in Montreal, I suggest you also check out Totem Acoustic.
Frank.
Entry level for the Revel range, would also be useful to explore....
Posted on: 05 June 2016 by yeti42
As Frank says, Totem are worth an audition. Their entry level Dreamcatcher is particularly entertaining but you must audition at home, particularly speakers can sound very different in a dealers dem room.
Posted on: 05 June 2016 by Simon-in-Suffolk
A music buddy of mine uses Russell K Red 50 stand mount speakers on Something Solid stands with  his 112/115 system and they simply sound fantastic
Simon
Posted on: 05 June 2016 by gary yeowell
Yep, Russell K 50 would be on my shopping list without a doubt. The 100 is even better, looks aside….
Posted on: 05 June 2016 by cat345
Hi Gilles,
Your ''geriatric'' TLS 50's as you say were some of the best loudspeakers of it's time and they could be difficult to replace today with modern looking speakers without spending a lot. As you are accustomed to the fine quality of bass from your IMF's,  you could have the crossovers rebuilded for a reasonable price or try to demo some PMC speakers that are also transmission lines.
Posted on: 05 June 2016 by ChrisSU
gary yeowell posted:
I heard the K100s with a V1/NAP100 any was very impressed too. You can, at extra cost, get them in a traditional wood veneer if the styling isn't to your taste. I certainly couldn't live with the cheaper red and grey finish.
Posted on: 05 June 2016 by badlands
Seek out Elac speakers, try to audition. They will surprise you, and will compete with those speakers you mention, and save you a lot of money also.
ChrisSU posted:
Yes they look much better in the extra cost wood finish. I couldn't live with the toy town red and grey either. Bloody good speaker though… i heard them with a 272/XPSDR/250DR and they relished the juice.
Posted on: 05 June 2016 by wenger2015
Heard some Russel K's at the Bristol show recently , met the designer, although I didn't realise it at the time,  but speakers definitely worth a demo ..
Posted on: 05 June 2016 by analogmusic
Songs Faber chameleon range (very good with Naim)
Dynaudio Emit range or Excite range (X14 in particular, and X34)
ProAC studio range (amazing)
Posted on: 05 June 2016 by Iconoclast
I doubt he'll be able to audition Russell Ks in the Montreal area. A pair of Proac Studio 118s would be a pretty safe bet.
Posted on: 05 June 2016 by DavidDever
I'd give the U.S. distributor for Russell K a call - they may know where one can audition the Red Series loudspeakers nearby to the Montreal area. They're well worth a listen, and the designer knows his stuff.
Posted on: 06 June 2016 by Jan-Erik Nordoen
Bonjour Gilles,
Have a listen to some of the Davis Acoustics speakers. They're a well-established French company who build their own drivers and also supply some well-known speaker companies. I bought their compact Olympia Master One, because the speaker's midrange is simply one of the best I've heard in years, with bass that reaches down easily to 40 Hz and that never intrudes on the midrange. Voices are uncanny.
Audio d'Occasion carries them and are also the distributor.
You've not mentioned the size of your listening room, but Davis has a full range of speakers, so it shouldn't be too hard to find one that matches your room.
Jan
Posted on: 06 June 2016 by Michaudg
cat345 posted:
Hi Gilles,
I think You are absolutely right. I will try to listen to the PMC's. Thanks for your time and generosity.
