Pro-ject Essential + Stageline
Posted by: Ardbeg10y on 06 June 2016
Dear Naim Friends,
I need some advice and consider this place the best to ask for independent advice. I've bought a Supernait last year which has a CD5i + Chromecast Audio attached. CM1 Speakers. During daytime, its used for mid-fi kind of listening whilst I'm coding software.
I've discovered that it greatly relaxes me when I use the setup in the evening for concentrated listening to e.g. symphonies ... put chair on right spot, slightly turn speakers inwards, glas of red wine and this planet is somewhere halfway part 1 of a symphony a much better place.
Therefore I'd like to explore this more by adding a good source: a turntable. Since there are some good records in the family, this would be a pretty easy and relatively cheap way to go. My particular interest is in the Pro-ject Essential turntable.
At first, I'd like to buy the TT and a relatively cheap Phono Stage. In a later stage - when funds allow - I'd like to replace the relatively cheap Phono Stage with a Stageline.
I've been reading that the Stageline gets its energy from the Supernait. Is that true?
Also, I'd like to add a Hicap to the Supernait to feed it's pre-amp stage. Could I connect both the Stageline + the pre-amp stage of the Supernait to the same Hicap?
Has anyone experience on the Stageline + the Pro-ject Essential?
