Help needed: can someone run a small test?
Posted by: thijazi on 10 June 2016
If you are running a Naim DAC-V1 connected to either PC, MAC, Sonore Microrendu or any other USB interface to the Naim DAC-V1, and if have any music in 176.4/24 bit FLAC format can you please run a brief test? It would help me determine how frequently this issue appears in Naim DAC-V1 or if my DAC has an issue.
Press and hold the USB button on the DAC until the USB status screen is showing and then playback a 176.4/24 bit track and let me know if the USB buffer continues to drop from the +60% until it reaches a lowly 15-20% before the buffer jumps back up, for me this jump is always accompanied by a clearly audible "click/pop". I tried a MAC instead of my Windows PC with the same result, I swapped the USB cables, copied the files to local storage, did everything I can think off, the buffering issue is still there.
Funny enough the buffer is stable if I playback 192/24bit files which are larger! Go figure...
Thanks.
