CDX2 broken?
Posted by: lescouse on 11 June 2016
I have just bought a second hand CDX2 2006 vintage, it sounds amazing, so a good purchase.
However the 'Naim arc' doesn't light up. Does anyone know if it should light up and therefore I have a fault that requires rectifying or does the Naim logo not light up on a cdx2?
Or am I missing a trick?
Posted on: 11 June 2016 by Richard Dane
It should light up when the unit is powered up.
Posted on: 11 June 2016 by Finkfan
+1 for that. The buttons and logo should either all be on or all off
If nothing is lit. Press cd on your remote. Then press display.
Posted on: 11 June 2016 by lescouse
I'm pretty sure I have a fault
I can switch the display on and off, but the logo is out.....
I will give it a switch off and see if that cures the problem, otherwise the cd2x will be paying a visit to Sailsbury
The logo must always be lit when switched on, even if the display is switched off.
Yup got a fault and a warranty....
'thanks
Richard Dane posted:
Oh yeah! It's been a while since I've had time to listen in the dark!
Posted on: 11 June 2016 by joe9407
Am I misremembering things, or could the brightness of the logo on units of that vintage be adjusted somehow?
Posted on: 11 June 2016 by badlands
joe9407 posted:
That would be a negative!
Posted on: 11 June 2016 by joerand
lescouse posted:
lescouse posted:
Second hand and 2006 - hard to imagine you have a warranty.
Question now is whether you can live without a lit logo or want to pay to have it repaired.
Posted on: 12 June 2016 by Christopher_M
joerand posted:
Bought secondhand from a UK Naim dealer one could expect a 3 month warranty.
Chris
Posted on: 12 June 2016 by joerand
In that case you ought to be taking up the matter with the dealer. Hope you get it fixed
Posted on: 12 June 2016 by lescouse
I have a 12 months warranty ......nice!
its a minor fault but i want it fixed and I love looking at those green logos in the dark
Thanks to everyone
