Muso, QB, Tidal and my experience
Posted by: Wonderland on 12 June 2016
Hi all, first time posting!
Bit of background- After years of avoiding steaming or downloaded music due to what I think is unacceptable sound quality (and i'm a bit of a technophobe) a month ago I decided after reading up on the advances in SQTidal has made that I'd give it a shot. I have a large CD and vinyl collection that isn't well organised and I can never find anything that I'm looking for so I thought for convenience Tidal would be perfect as I'd read a lot of good things about the SQ and it was about time I stepped into the 21st century.
To cut a long story I spend a week lifting floorboards,drilling through walls and teaching myself via you tube how to wire a cat5e network as I definitely wanted the streamer wired. All was ready to just go and purchase a streamer.
At my local hi fi dealer I was instantly sold on a muso for the lounge and obviously a QB for the kitchen, it was in the back of my mind that id be purchasing another QB for the bedroom before the end of year also.
What attracted me to the muso and Qb was a few things- They look great, They sound incredible for all in one boxes, they can be fully integrated into a seamless network for multi room sound and they are ready set for Tidal. Perfect.
The hi fi salesman auditioned them for me with Tidal in the listening room and I thought it sounded incredible.
So i get them home, plug them in to network, straight on to Tidal and after a few seconds silence a pattern which repeated. Tidal was un usable for me.
Then I start looking into Tidal Streaming problems and come across all the negative feedback.
I looked at my internet speed and decided it was pretty crappy, my provider was Sky and the best I was getting was 5-6 mbps. I thought this is the problem so I moved to Virgin fibre and took out an 18 month contract that guarantees 50mbps.
When the fibre was installed the other day I eagerly plugged the streamers straight in. Perfect sound for 10 seconds then you guessed it silence etc.. etc...
Speed test was sure enough 50mbps. I spent the day on the phone with Virgin with them rebooting the hub and claiming all was fine there end the problem is the streamers.
I then find the negative feedback about the virgin super hub routers.
After taking out a more expensive internet service to be supplied with a sub standard hub really peeved me off but i got on with the job of looking into routers.
Finally settled on a net gear r7000. Again got home plugged it in. Set it up with Qos to the streamers, same thing Tidal cannot make it through a song. (spottify does but sounds terrible IMO)
The point of this post is firstly does anyone have any advice for what else I can do to make this work. I am more than prepared to pay the £20.00 a month for hi fi streaming but from my experience and what I have read since Tidal simply does not work.
Secondly is it me or should naim not be advertising seamless Tidal integration because I feel like I was sold the Muso and QB and they are not fit for the purpose I purchased them for. I have basically been left with 2 very expensive radios.
