Hi All,
I am having trouble getting a streaming device to work properly (sync issues) on my Naim DAC (software version 4.11.8) but works fine on my friend's DAC (software version 4.11.7 - beta?)
4.11.7 v is not available on Naim's website but perhaps someone could email these file to help troubleshoot the issue, please?
Many thanks!
Pat
Posted on: 20 June 2016 by PatB
Thanks fr the suggestion. I did Steve a call and he suggested a possible mismatch / issue of the clock found on the output board I am using and a type or even quality (how they're put together) of cables; resulting in a mismatch that could, in some cases, amplify certain out-of-spec oscillating clocks. I will do some more testing between my friend's set up (cables, streaming devices etc.) and update the post if we end up with any regularities.
