Other uses for AV receiver
Posted by: ROOG on 25 June 2016
Sorry if this is a daft question, but I don't have much experience of AV receivers.
I have a new audio DIY project on the go, and it involves Tri amping.
An active crossover giving Low, med & high frequency outputs to an amplifier which is used to drive 3 individual speaker drivers per stereo channel,  so I need a 6 channel amplifier.
As its a DIY prototype I don't want to spend a fortune on a Tri amp set up and I thought that an old AV receiver might be ok to get the project off the blocks.
I note that some older 7.1 receivers have Multi channel inputs marked:  front L&R, Surround L&R and Rear surround L&R. I understand that these are intended to accept inputs from specific types of DVD players.
Question is: in Multi Channel mode are these inputs routed through the amp on separate channels with out any processing carried out?
purpose being to use it as a; "not so hiFi stereo Tri amp"?
 Thanks for reading
Posted on: 25 June 2016 by NickSeattle
Yes.  That will work.  The point of the multi-channel input is to allow for processing, if any, outside the AV amp.
l used this method once to power a whole house system in stereo, ignoring 5.1 completely.
Nick
Posted on: 26 June 2016 by tonym
Yes, agreed it'll work a treat. I think folks underestimate how good the amplification can be in A/V receivers.
Posted on: 26 June 2016 by ROOG
Cheers chaps,
i presume that the signal will pass through a volume control section and may be EQ, which would be quite handy.
I'm looking for an Arcam receiver which I hope will use reasonable amplifier sections.
thanks for the advice, appreciated.
Posted on: 26 June 2016 by Eloise
Yes it will work.
As an alternative you could look for a 6 channel Rotel such as the RB976 or RMB1066 which are often available at good cost and will be a similar quality amplification to that in an AVR.
Oh yes, keeping my eye open for multi Channel power amps, NAD, Arcam and Rotel, but these seem to be rarer and more sought after.
Spotted a massive Vincent 6 channel power amp beast, but it's a bit rich for my test bed.
