US oddities
Posted by: Richard Morris on 30 June 2016
A couple of things I've noticed:
if a cd is reported as 'unknown' and you abort mid-rip the display on the iPhone app does not clear. Subsequent cds are not recognised and a reboot is necessary. If you let the rip complete this problem doesn't occur. (Reported to Naim)
Occasionally the iPad app (and n-Serve) will retrieve a cover and put it into the metadata but the iPhone app won't, even after a cache refresh. The only solution is to manually edit the record in the iPhone app.
Posted on: 02 July 2016 by Adam Zielinski
Perhaps you need a new iPhone ? Looks like the only common variable between the two 'problems' is the iPhone....'
Posted on: 03 July 2016 by Richard Morris
Interesting response. The other common variable is Naim software, is it not?
Posted on: 03 July 2016 by hungryhalibut
When I had a Serve, I let unknown albums rip and then added the track names, art etc via the nServe app.  It always worked fine. Maybe the answer is not to abort them.
Posted on: 03 July 2016 by Adam Zielinski
I second this - let the album rip.
Also use iPad n-Serve to control the ripping process - very stable. iPhone is a bit too small for that.
