Touching up
Posted by: Will Dias on 30 June 2016
My CDX has a shiny corner where the paint has worn. What is the recommended paint to touch-up Olive products?
Will.
Posted on: 01 July 2016 by hungryhalibut
When I had olive stuff I used a black marker pen.
Posted on: 01 July 2016 by Andrew Porter
...or black shoe polish works well!
Posted on: 01 July 2016 by Pcd
I used black shoe polish as well worked wll.
Posted on: 01 July 2016 by Richard Dane
For tiny little areas of paint loss it's best to use a fine-tip permanent black marker - you need to find one that is properly black and doesn't leave a rose-tint.
The shoe polish is ideal to make the cases look good, but won't work on any shiny corners.
Posted on: 01 July 2016 by Yetizone
I tend to use black artists acrylic paint (water based), it dries to a matt / satin finish and is more or less indistinguishable once dry. Two light coats with a (very) fine brush to layer the paint, dampening off any excess with a MF cloth.  I found that a black marker can fade over time. I used this effectively on my chrome bumper Nait 2 to hide a couple of marks where the anodising had worn over time and it completely covered the effected areas.
Posted on: 01 July 2016 by mlauner
Sharpie marker works well
Posted on: 04 July 2016 by Will Dias
Thanks all, black marker pen used, and I'll monitor durability. Will
Posted on: 04 July 2016 by dayjay
The title of this thread is very misleading to the casual viewer! Should have added +1 on black marker pen but test it firsts because some have a slight purple colour to them
I was somewhat concerned as to the ambiguous title, and the potential for confusion. Don't titter.
Posted on: 05 July 2016 by Darran H
Will Dias posted:
Will.
Do you have a Games Workshop close by ?
Abaddon Black is the paint to use.....   With a very thin brush..
