Sonos and NDX
Posted by: dlfq on 03 July 2016
I would like to use my Sonos to play Deezer through the NDX. not sure how the connections should run?
thanks
You'd need a Sonos Connect which would has S/PDIF outputs (both optical and coaxial).
Connect one of these with the appropriate cable to one of the digital inputs on the NDX.
James
thanks, yes the connect has the outputs. i will have to get another cable i assume either coaxial or optical will do?
i see the naim has the below..which is the most appropriate to use with the Sonos?
thanks
3 x S/PDIF: |
Any will be fine... I personally use the TOSLINK connection between Sonos and NDX
Whatever is handy, to start. Some people prefer optical, others co-ax into RCA or BNC.
I liked BNC best for the Connect, when I had one.
I bought the fittings, wire, and tools to make my own RCA to BNC. It compared well to a similar Naim DC-1, in my experience.
Nick
To clarify, I tried both the DC-1 and my home-made wire and neither made the Connect sound as good as any of my other digital sources, even when I gave the Connect the advantage of the Naim interconnect. Squeezebox Touch, Mac Mini, NDX all beat the Connect, to my disappointment.
Pleasantly surprising was how good the home-made interconnect was.
Nick
