Tidal account unlink?
Posted by: Javi A. on 09 July 2016
Hi to all!!
I just upgrade from a UQ2 to a SU. The SU i got was second hand and come with 3.3 firmware. I upgrade it to 4.4 without any problem and Tidal appears again. Using my android table all my tidal favorites where there without logging anywhere (i mean not configuring anything on the tablet or SU).
Now it is time to sold the UQ2. How I delete all UQ2 data including my tidal account? Where my tidal credentials are instaled in (tablet of Naim)? How can I manage them in case for example of changing my tidal account name?
Thanks in advance for your help.
...Javi
Posted on: 09 July 2016 by ChrisSU
The Tidal account is stored on the app, not the streamer, so you don't need to worry about it. Having said that, it will probably help the buyer if you reset the Qute to its factory settings so they can set it up as they want from scratch, especially the network settings.
Posted on: 09 July 2016 by Javi A.
Thanks for your reply. I can not remember how I setup tidal after its update to the 4.4 firmware.
...Javi
