Hi have taken the fronts off my Credos. To my absolute horror, I have Somehow now got the dome on one the tweeters pushed in, (small fingers perhaps)
Its been a couple of years since I last took the fronts off, and have noticed no difference. I am about to have my CDS serviced and the capacitors changed.. Should I change the tweeter, 1 or both? What are they and can you still get them?
cheers Mike.
Posted on: 13 July 2016 by Stephen Tate
Hi Mike,
I would not worry about it, just very carefully (at a distance of course) use a hoover nozzle and suck it back out, all will be fine.
Steve
Posted on: 13 July 2016 by dayjay
+1, careful use of a Hoover. My niece pushed in all of the cones on my old Guru Juniors which was a real shock. I used my Hoover on its lowest power setting and they popped out just fine. Even pressed in it doesn't affect the sound but it's easy enough to fix
Posted on: 13 July 2016 by ChrisSU
I once had some Royd tweeters suffer a similar fate at the hand of a curious toddler. I managed to restore them by repeatedly pulling at them with a bit of adhesive tape. I used parcel tape as it's low tack, rather than very sticky stuff like gaffer tape. Cosmetically, thay weren't quite perfect, but thay still sounded fine.
