Phono or din cables. Qute 2 & NAP 100
Posted by: Jezza on 15 July 2016
I have a Qute 2 and have now purchased and connected a Nap100 to it.
Is this considered a good match?
I have them connected by two pretty inexpensive phono leads.
Could someone suggest good phono leads? (without going too ludicrously expensive)
Or what type of din leads or din to phono lead maybe a good choice?
Are the qute and nap 100 both 4 pin dins?
Jezza
Posted on: 15 July 2016 by charlesphoto
Possibly the 4 pin Din cable that should come with the 100 is your best bet?
Posted on: 15 July 2016 by feeling_zen
Atlas Equator Integra are probably about the right level on RCA-RCA. Like all Atlas cables, special care has been taken to minimise the resistance step between cable and plug. Otherwise if you want to use the DIN input on the NAP100 they do the "Element DIN to Integra RCA" lean.
Both are low cost but good quality.
Posted on: 15 July 2016 by Eloise
I'm (was) using a cable from Flashback Sales to connect a UnitiQute to NAP200.
