Mobile signal boosters
Posted by: intothevoid on 17 July 2016
Anyone have any thoughts or experience with these?  There's only a weak signal in our local area and none indoors.
My wide and I are both on O2 through work contracts so TU GO isn't an option.
Looking at several GSM boosters that are available online and would be interested to hear if they live up to their claims.
thx
Posted on: 17 July 2016 by Tony Lockhart
As far as I know, illegal now.
Go with EE if you can, and the wifi is used for calls and texts. Flawless. And free.
Posted on: 17 July 2016 by intothevoid
Tony Lockhart posted:
Unfortunately we're both tied to O2 through work contracts.
I'd read that cell repeaters were ok. Not sure what the difference is though.
Posted on: 17 July 2016 by Willy
In the past I've used one supplied by Vodafone and currently use a Three supplied femtocell. Much better than wifi calling. With the Vodafone one I had it on a timer to physically reboot every night. The Three one needs a reboot every 5-6 months on average. Otherwise they have been very reliable and behave just as intended giving us a localised 3g hot spot. Of course if your broadband goes down (BT, need I say more) you're back to standing on the shed roof. Only problem I've had is with my Nexus 6 sometimes not connecting automatically though that seems to be more to do with running android N beta software.
Willy.
Posted on: 17 July 2016 by Harry
When with Orange I used Blackberries that routed the signal through WiFi (UMA). EE stopped supporting this so we went to O2 and got a Boost Box. Problem solved.
Posted on: 17 July 2016 by Bart
Wifi calling absolutely is the best option, if available from your carrier.  It may require you to buy new phones, but when it's set up, the quality (can be) is phenomenal.
Three support both the dedicated signal booster (femtocell) and wifi calling. In my experience the femtocell is better in terms of quality (indistinguishable from normal cell whereas the WiFi calling is of lower quality) and reliability (excepting the issue with android beta software on my phone it always works seamlessly whereas the WiFi calling doesn't always work, indeed it won't work at all with my daughter's Sony phone).
Willy.
Posted on: 18 July 2016 by Chris G
My business contract is with O2 which has a terrible signal where I live, so I asked O2 for a Boostbox, which enables me to send and receive calls fo/from my mobile - it works very well most of the time
Posted on: 19 July 2016 by ChrisSU
I've been using three wifi calling for a while now as calls in our thick walled house usually fail. The app is basic and not well integrated into the phone, but it works. The more recently introduced EE, and now O2 versions look like they are better designed.
As for their being free, there is an argument that they should pay us for the use of our network when calls are routed through it to make up for the inadequacies of theirs.
Posted on: 19 July 2016 by intothevoid
Thanks for the replies. Sounds familiar; TuGo wifi calling VERY unreliable and not available on business contract.
Harry, how did you get the boostbox? Guessing you're not a retail customer?
Posted on: 19 July 2016 by Harry
I opened a business account with them. It was actually a very good deal by any measure but my focus was on getting the Boostbox. Cellular coverage where I live is zero. Orange gave me calls over WiFi, EE dumped the lot and me with it. I was forced to choose another provider but after only a few months with EE I couldn't jump fast enough. O2 do a WiFi app but it's pants. The Boostbox has been nearly faultless and well supported - a big plus point.
Posted on: 20 July 2016 by intothevoid
ok, thanks. I'll see if I can follow that up with O2.
