Watch winders
Posted by: count.d on 21 July 2016
Just bought this new Heuer Monaco watch. I now have two automatic watches, so will probably need a watch winder. I have Googled this subject, but it seems a bit of a minefield on first look. Does anyone have experience on this subject? Do the winders have timers on them, so they're not always moving? Is it best to get one that has different movements, so it's not winding the watch in the same direction all the time?
13769500_10153911392443655_4165641850372099636_n
Posted on: 21 July 2016 by Steve2
Stick the watch on the end of your arm.  As you move about during the course of the day the movement of your body will wind your watch for you provided of course it has a self winding mechanism in it.  My Omega Seamaster is still keeping good time 20 years after first purchasing it.  If wearing a watch on your wrist is a real hassle which it can be for people with sensitive skin, get a clock and hang it on the wall.  Problem solved.
Posted on: 21 July 2016 by u77033103172058601
I have a Rapport unit, which has served me well for the last 5 years. Rotates the watch back and forwards in one of 3 different timers. My Breitling will only last 2 days without a self-winding charge and I have another 3 watches that vie for my attention. The winder is a must. About £300, which seemed good value compared to some I looked at.
Posted on: 21 July 2016 by Tony Lockhart
Glad I only have the Daytona to think about. Worn every day, as it should be.
Gorgeous Monaco by the way
Posted on: 21 July 2016 by winkyincanada
Steve2 posted:
The OP said that they have two automatic watches, hence the potential benefit of a winder.
(My automatic Tag chronometer has been on my wrist for ~17 years. I wear it 24/7. The band has had pins fail on two occasions, each time causing the watch to fall to the ground, but the watch has never been serviced or repaired, apart from a calibration it needed soon after purchase. The most remarkable thing has been the glass which remains completely scratch-free in-spite of it actually protruding above the bezel a bit.)
Posted on: 21 July 2016 by count.d
Thanks Nick. Rapport is a good starting point to look at. What timer lengths are your winder options?
Thanks Tony. I like the shade of blue this edition and particularly the matt face.
Winky, if it's not been serviced in 17 years, I think you've been lucky with the movement still working fine. Is your glass sapphire crystal, as it's particularly resistant to scratching?
Posted on: 21 July 2016 by Guy007
Count, nice watch I have the black/silver Calibre 12 version, which is about 6 years old now.
I use the Wolf Designs ( now known as Wolf 1834 ) Module 4.1 winder, set to 600 rotations and turning both ways. I also use the 'foot' to raise it and angle it back slightly.  They have other singles and finishes, so depending on where you are placing it you could 'match' or contrast the furniture.  Mine is closer to the bed, so I would recommend a covered front option if that is the case (helps with dust too) and depending on your sensitivity to a low rotation noise.
One word of warning, with the Chrono, they are not a watch for too sporty an activity - running/gym et al - as I found out, and luckily within the first year so it was repaired free.   Driving and walking is all good though. Enjoy the watch.
count.d posted:
Yeah, I know. I suppose I'm waiting for it to fail.
I don't know what the glass is, but it is seemingly scratch proof.
Posted on: 21 July 2016 by joerand
No intent to sound judgmental, but I could never have imagined such an esoteric need exists. Verily a first world problem, though realistically so are most topics on this forum. I'm thrilled that my 2008 flip phone with its original battery still maintains accurate time, works flawlessly, and I can unimpressively wear it in my pocket.
Posted on: 22 July 2016 by Harry
I use a Time Tutelary Black Dome Automatic Watch Winder KA083. It's a brittle, plastic, piece of Ronco toot which does exactly what it says on the box and for my needs doesn't need to look flash or classy because it sits at the back of my office, winding the watch I'm not wearing. I only have the two. I'm not 100% confident it will accommodate a Monaco. Although I don't know.
Posted on: 22 July 2016 by Guy007
joerand posted:
Joe, but your phone has a battery, the automatic does not.  The only issue is when you have more than one...
Life is all about choices, on here it's should I go top of the audio pile or lower down, but with broader interests else where, be it watches, cars, photography, properties, travel, wine et al
But as you point out, most on here have first world problems, but luckily 'birds of a feather flock together' and can help out.
Posted on: 22 July 2016 by count.d
Thanks Harry, I'll take a look.
You probably already know this, but it's the seals that need servicing too, or they leak air and this then deteriorates the face/hands a lot faster.
Thanks Guy. What's the specific reason to raise the foot, so it angles it back?
When you say you had a problem with yours during sport, what was it? What damage was done?
Posted on: 23 July 2016 by tonym
For the last fourteen years or so, I've more or less exclusively worn a Seiko Kinetic watch. Keeps perfect time, no batteries. You can leave it for a couple of weeks (I had to leave mine off for a spell in hospital) & when you next pick it up the hands go round to the correct time. When it eventually expires I shall get another one.
Posted on: 23 July 2016 by u77033103172058601
count.d posted:
Not sure what the options are, but the winder, in operation, rocks the watch for about 30s and then stops for about 15 minutes, when set to 'maximum agitation' mode. There are 2 lesser modes. But I find that my Breitling will not charge itself unless I use the maximum agitation mode. Doesn't the Rapport website give technical details?
Posted on: 23 July 2016 by Guy007
count.d posted:
Count.  The foot serves two purposes for me 1) It makes getting the cover off easily, so no risk of scraping the table 2) In having it angled back the heavier watch like the Monaco is unlikely to fall out if not 'clicked in' correctly - I had an earlier (10 years ago) Module 2, with no cover and that sat flush. If not clipped in correctly, the watch would occasionally work free and pop out. Also hence my previous comment about noise too.
With the watch I was using it for running, cycling, gym, tennis etc,  It started loosing time and you could feel something wasn't right when turning the crown.  Anyways it was within the 1st year, they replaced the whole movement. I was advised Chrono's are more sensitive and more costly to repair, so I've treated it more carefully and had no issues since then. i.e. no 'jarring' sport.  My Monaco was actually a replacement for a 2000 series Automatic I got for my 21st, but was stolen in a break in.
I would also endorse Tony's comment on Seiko Kinetic, I use one when traveling.
Posted on: 24 July 2016 by count.d
Thank Nick. I could only see the Rapport site saying fast wind or timed modes, but no specific details.
Thanks Guy.
Yes Tony, Seiko do very nice watches and I've always liked them.
Posted on: 31 July 2016 by shoot6x7
tonym posted:
I've had a Seiko Kinetic for nearly 20 years, it was last service in the early 2000's.  It has a capacitor and a flywheel for self-charging.  A traditional winder will not work as the smooth motion doesn't generate the charging current, it needs a flick kind of motion in the turn cycle.
I did see that many are converting their inductive electric toothbrush chargers into a charger for the watch !  I've not risked it ...
Posted on: 01 August 2016 by tonym
Hi Shoot, good to see you're still around! Hope you're keeping well.
Posted on: 01 August 2016 by Bob the Builder
It depends if you wear it everyday I have one of the new Tissot visodate which is also automatic but because of my job I cannot wear it everyday and so have to wind it and reset it everytime I want to wear it which is a real pain but there are worse things in life, my Dad who has a small collection has a couple of winders and swears by them.
Posted on: 01 August 2016 by Cbr600
Have a look at Klarstein winders if you want a traditional design, or if interested in something more "out there" have a look at MTS winders with some funky designs.
definately stay away from cheap import stuff that has poor lifespan to failure.
also need to think if you intend to buy more watches, to plan ahead with a 3 or 4 unit winder!
Posted on: 01 August 2016 by shoot6x7
tonym posted:
You too Tony !!
Posted on: 02 August 2016 by count.d
Thanks for the further suggestions. I've looked into various manufacturers and it doesn't seem to be simple subject. Maybe I'm looking too hard. They do seem to be expensive, especially if you want flexibility of adjustments. I like the idea of an advanced model which allows it to be connected to a computer to infinity adjust the number & direction of turns per day.
Posted on: 05 August 2016 by blythe
I bought a 6 watch winding box from watch-winder .co .uk for only £173 which seems a bargain!!
It has three different winding modes, altering duration and frequency of winds, which operates in both directions. Two watches per winding drum (if that's the right terminology)
Posted on: 07 August 2016 by count.d
Apparently I have to choose a winder that is guaranteed to have the motor shielded, so the watch does't get affected by a magnetic field.
