Amp for proac studio 140
Posted by: cuciu76 on 27 July 2016
Hi everybody,
i'm looking for an amp for my proac speakers. At the moment i'm using an av pre (nad t175 with an arcam p1000) but i'd like to upgrade it choosing a stereo amp. What do u suggest ? Naim i5s, xs2, or 152/155? What does suit with proac better?
tks
Posted on: 18 August 2016 by cuciu76
Any ideas? Better a second hand nac202 or a new xs2?
tks
Posted on: 18 August 2016 by b_lund
cuciu76 posted:
Hi everybody,
tks
If by stereoamp you mean one amp =integrated amp
Then any Nait will do, something like a second hand 5i is usually a good purchase, so are XS which I think is too expensive new. The Supernait is the largest integrated amp from Naim, version 1 has dac inside, Supernait 2 has not.
The 152/155 is two box pre,power, not sure they are so much better than XS
The Nac 202 is a preamp only
Used Naim equipment in good condition is often free hifi as resale value could hold equal, once a friend had some 25 years old Nap 135 mono poweramps, they sold with no loss, owners of Nait 2 could be lucky selling with a huge earning these days
Posted on: 18 August 2016 by cat345
b_lund posted:
cuciu76 posted:
Hi everybody,
tks
...and they will regret that ephemeral lucky moment thereafter for all their life.
CUCUI76, any Naim integrated will be ok with the ProAc 140.
Posted on: 19 August 2016 by Dan.S
UQ drives these with ease. Tested!
Posted on: 19 August 2016 by cuciu76
UQ what model is?
tks
Posted on: 21 August 2016 by Olek_K
I currently have ProAc 148 so I would be interested to hear users opinion regarding varoius amps. Would 5si/i sound great or it's worth going to xs2? Or else?
I sold my nac272/200 some time ago and I regret help needed!
UQ = Unitiqute
Posted on: 21 August 2016 by DrMark
I home demoed a pair of Studio 140s some time back (eventually went with the Response D2s) and drove them well with my Nait XS. Any iteration of Nait XS or a SN1 or 2 (until recently I owned a SN1) should give you anything you could hope for.
Posted on: 22 August 2016 by cuciu76
I'm thinking about a new xs2 or nac152xs + nap155 (second hand). Better the second one?
Posted on: 23 August 2016 by BNN
If budget allow, please go for SuperNait (2nd hand) or SuperNait2. If integrated amp not your vege, then try at least 202/200. ProAc Speaker easy to drive but need them to max the performance you need higher grade amp. Suggest if you prefer bold and sweet sound then you must try Audio Note amp (entry level Audio Note Integrated amp will do, 18W class A). Very different sounding but can listen for long without bored.
