Android App in more than one table/device?
Posted by: Javi A. on 01 August 2016
Hi to all,
I use the naim app in my Benq tablet. The question that I have... is it possible to use it in a second tablet? Will I have any problem with tidal account? I ask this because I am planning to buy a second tablet and I would like to control the Superuniti using both devices at the same time.
...Javi
Posted on: 01 August 2016 by ChrisSU
You can only use the Naim app on one device at a time, but you just have to close it on one before you open it on another.
If you create playlists on the Naim app, they are stored on the individual Android or iOS device, so they will not appear on another device unless you transfer them manually. If that's a problem for you, better to manage playlists on the UPnP server.
Posted on: 01 August 2016 by Javi A.
Great!
Thanks for the info!
...Javi
