playlists on the US
Posted by: Richard Morris on 04 August 2016
I've ripped a load of my wife's albums and put them into a playlist. She uses the naim app on her iPhone to play them through a Mu-so.
The problem is - the playlist shows tracks, not albums (as in iTunes) and she wishes to browse and play the latter, not single tracks.. Am I missing something?
The only workaround I can see is to create a custom genre and allocate that to her music.
All advice welcome.
Posted on: 05 August 2016 by ChrisSU
A playlist will, as you say, only list tracks. Your workaround using a genre seems like the obvious solution......be careful what you call it though!
With a non-Naim server you may find there are other options for creating your own folders, but not on the US.
Posted on: 05 August 2016 by Richard Morris
Thanks.
