Uniti 2 interrupted firmware update
Posted by: dschoem on 07 August 2016
Apologies if this has been covered elsewhere on this forum. I need some assistance. I was in the process of upgrading my Uniti2 to the latest 4.04 firmware. The unit was running 3.15 at that point. I ran the update using a Windows 10 machine via the mini-USB socket at the rear of the Uniti2, and the installer programme downloaded from the Naim Audio Support site. Both the Uniti2 and the Windows 10 laptop were linked to a router and Internet via Ethernet. All went well, and the firmware started updating on the Uniti2. However, the Windows machine went into sleep mode after 10 minutes (yes, I forgot to switch off the auto sleep mode setting) , and when I woke up the PC I got an error box with the header: Update Failed: Incompatible Firmware Version. The error message in the box reads: "The product rejected the firmware version as it is incompatible. Please contact Naim technical support." The display on the Uniti2 reads: "Please update streaming firmware. IP 0.0.0.0 Need v13031 or higher." Any suggestions on how to proceed? My options are to retry or abort - retry only brings me back to the same error message. Should/can I abort and restart the process?
