Does UPnP Streaming make any sense for a single zone music system?
Posted by: aysil on 16 July 2011
The main features of UPnP streaming seem to be the possibility to stream multiple zones with different music, and interoperatability of devices and softwares of different brands on the network. The latter does not seem not unproblematic, as all those using non-Naim control points report some problems.
Two of the network players from Naim use another method, file sharing, to play music files on the network: HDX and UServe. Naim makes a confusing distinction for reasons I don't understand and calls them "harddisk players" instead of network players. They have basicly the same functionality in playing network files as the NDX and Uniti(Cute), which use UPnP streaming for the same purpose.
According to my experience, sound characteristic differences between all these (five) devices does not depend on the method they use to reach the network files. In short: UPnP streaming does not have any sq advantage in itself - and possibly a disadvantage.
I've been comparing NDX and HDX in playin back music downloads stored in my computer (it could have been a NAS) and feeding an external dac (nDAC): In all instances, especially with high-res material, HDX sounds slightly superior to me. Moreover, the file sharing method of HDX seems less sensitive to network configuration and/or processor load in the server end of the streaming. (File sharing does not need any server at all; it needs only that the files are allowed for sharing.)
My conclusion is that the method implemented in HDX for feeding the network files into the playback chain is actually a good one and Naim should develop further on this line. The reason why many people are purchasing and enjoying the NDX at the moment is because Naim is not offering a stripped down version of HDX without the ripping machine. Those people who have already ripped most of their CD's are not interested in it because of the higher price. For those who already own a UServe, the NDX makes sense as an upgrade because the dig-out of UServe is not exactly up to the same level as HDX (or NDX). However, if you're beginning all over, HDX makes more sense than UServe+NDX combination because its price is lower than the combination (and because n-Serve has playlist support now contrary to n-stream).
Anyway, before I write too long on this line of thought, do you have any comments?
Keep in mind that there are BOTH Servers and Renderers.
It is easy to confuse them because the Servers Naim offers have local digital (and analog in the case of HDX/NS0X) output.
Renderers must slave themselves to the Servers they can see and operate according to the Server's rules. Naim's Servers on the other hand make multiple streams available to any renderers on the network.
Regarding the question in your Thread Title; if you dont want or cant have a computer near your hifi, then yes UPNP makes a ton of sense.
If you do have a computer near your digital inputs, you can use a USB converter or a decent sound card to supply the digital output. Of course this assumes SQ is on par with a UPNP method. Otherwise use UPNP either way.
-p
This is exactly my point: because Naim servers have local output, they function also as renderers and "network players". Therefore, I would formulate it the other way around: Some of the Naim network players have also UPnP server functionality (for multi zone use).
This is where I don't exactly agree. Even if the computer is not near your hifi, Naim servers can reach your music files, through network file sharing, on the ethernet network, and render them available for local playback. Therefore, UPnP streaming is not needed.
I don't want to be misunderstood: UPnP streaming works, even for single zone systems, and many manufacturers use this method. Naim showed an exemplary implementation of a UPnP client device with NDX. I just say it is not necessary; and I see advantages if Naim proceeds to develop the concept of computer-alike-music-server-with-local-output (like in HDX, UServe, NS0X) for future products.
You lost me............. That is UPNP streaming.
Both methods can work well. If the HDX's digital output sounds better to your ears than the NDX's, then by all means, use that!
I agree that two setups you describe are functionally equivalent in a single player context, with but minor differences. For example, as Patrick suggests, some of the UPnP server-side options can be handy. I ripped my entire CD collection to FLAC level 0, but Naim players sound a bit better playing WAVs. With Asset, I can have the server to transcode on the fly, thus giving me the best of both worlds. With the hard disk player model, I believe that re-ripping is the only current option. Also, when I was using my PC server as a "poor man's HDX", on occasion the file share would go missing, and I would have to figure out where it went. So far, at least, my UPnP service has always just "been there"', giving me a nice increase in reliability and availability. And yes, having UPnP set up also allows me to easily share my music library with the Denon AVR in my home theater setup, and, possibly, with a future second stereo I'm thinking about building around my old C7's (maybe with a UnitiQute).
Again, if I had an HDX, I'd be in no rush to switch to an NDX. But if I was starting from scratch, I think that UPnP has some advantages -- it is good, and getting better all the time. Lots of people are working on it, and it is part of the larger DLNA initiative. Finally, if Apple's AirPlay takes off, and if, as rumored, the NDX is going to support it, then that should also open up some very interesting possibilities.
Hook
No, UPnP is one protocol you can use.
UPnP may make sense if you live in the Microsoft world where it is supported and you have a (media-)server-centered approach.
Less so if you use Apple products (Apple thinks UPnP-progress moves to slow for their plans and does not support it). Apple is also using a decentralized approach - any client can own the big TV-screen (or Naim.system), you don't have to transfer the movie on your iPhone to a mediaserver somewhere - you can stream it to the big screen right from the phone. Apple is using HTTP (and HTTP Live Streaming) in its Airplay, this allow Airplay to stream directly from the internet (iTunes, iCloud or some cloud locker-type product).
HTTP Live Streaming is also the only video-streaming iPhone/iPad-apps support. It is very simple to setup and does not require special server-software beyond the normal web-server.
Naim support mostly UPnP but certain products (like the HDX) can also access network-storage (NAS) directly. I use my HDX-SSD with a NAS every day and it just works, I am very satisfied with my system right now.
For a lot of people, it makes sense to separate the storage of data from the Hi-fi replay system. Data storage, data backup, security access are a different set of problems than sound quality replay. From this point of view, music data is not different from any other type of data. It is therefore possible to use the existing IT devices, tools and methods.
Also when it comes to data management, it is considered more efficient to centralize the data in a single location. This makes backup easier as well as security access management.
Following the logic of specialization, the player should be physically separate from the data server. The player should be designed by the Hi-Fi experts and the data center should come from IT manufacturers.
Following the logic of data centralization, the music files must be centrally located instead of being stored over a multiplicity of devices.
Based on the above, a configuration with a NDX(player) or UnitiQute(player) communicating over UPNP to a separate NAS server follows best practice for both data management and sound quality.
I hope this will help clarify why many people consider NDX and UPnp the "correct" solution.
The same people would still admire UnitiServe and HDX, but mostly for their ability to provide an off-the-shelf solution to the ripping process and to the complexity of music metadata management. However, those people attached to the separation of data from Hi-Fi music system frown at the idea of storing the music files inside a music system. The SSD UnitiServe using an external separate NAS as a storage unit constitutes a good answer to those objections.
For the same people, the idea that HDX is a good tool because it can get data from multiple location is not appealing either because it appears as the "wrong" solution. Again, the "right" solution is for those people to centralize the data, not keep them spread out.
To summarize, for people who believe in these ideas, the correct way is to choose NDX as a player and UnitiServe SSD as a server, or a generic NAS with a Upnp server installed on it.
Best regard,
i said that? seriously... what the hell are you talking about?
imo Naim should be putting their efforts into making network music players and DACs that are utterly uninfluenced by how they are fed! It shouldn't make any difference to an nDAC where it's s/pdif is coming from, and it shouldn't make any difference to an NDX where on the network it's music data is being streamed from.
I know Linn have a different philosophy, but I have listened to their streamers and they don't do it for me. So I guess you pay your not insignificant money and makes your choice. :-)
Simon
Edit.. Likesmusic.. Good shout, but I wonder if that is somewhat like alchemy....
Simon, i think it is preposterous that the source of an ethernet packet should have any influence whatsoever on how it sounds when it is played back. My (£40 cheapo) network printer will print the same document whether I send it wirelessly, via ethernet or from my phone the other side of the world.
Surely if you were to start from scratch you wouldn't sit down and design an HDX -> NDX -> nDAC replay chain?
Hi Likes - I think that is what Naim has tried to do with its clever clocks and use of buffers - in effect created a virtual transport within the Naim DAC - I'm sure they will enhance this further when they have figured out how.
In the meantime feed the Naim DAC from the optical out of a MacBook and it sounds good - replace the optical with the V-Link USB to S/PDIF convertor and it sounds great.
Or feed the Naim DAC from coax out of a Sonus ZP90 and it sounds good - introduce the Wired 4 Sound board to Cullenise the ZP90 and it sounds great.
In both cases the cheap Cirrus chips give way to rather more expensive TI chips to reduce jitter and provide a better S/PDIF out - the Naim DAC seems to say thank you very much for giving me such a nice clean signal and duly obliges with even better SQ. It is, as Simon says, alchemy - pure and simple (possibly tainted with some magic), but my ears tell me it works.
The CDX2.2 is indeed a superb source for the Naim DAC, but a rather expensive one compared with those I use - similarly, the NDX would probably further improve on what I have, but I'm happy with what I have. In my view even a moderate outlay to improve the source feeding the Naim DAC returns dividends.
This applies equally to the UQ.
All the best, Guy
Best regard,
As it turns out, it is better practice to keep data spread across more than one physical location for purposes of fault tolerance–also, most NAS devices have limits on the amount of storage an individual device can handle (took much is never enough for some)–some of which is a consequence of the embedded processor architecture use to drive the NAS device.
The "right" solution from an end-user's perspective is to see all content as one source (even Apple Home Sharing cannot do this, in its current guise), across multiple storage devices.
In the case of the Naim servers, this happens by taking bog-standard CIFS/SMB ("Windows Sharing") sharepoints, cataloguing the contents, parsing the metadata, and offering up the complete contents (transcoded or decoded to WAV if required) as one content source for the end user.
This same, value-added model for content aggregation is used by a variety of enterprises (Google, anyone?), is time-tested, and works well.
Lastly–the HDX utilizes a fully-separate power supply for the analogue output stage, which itself is strategically located to minimize the effect of noise from other devices inside the chassis. The product was designed as a high-performance digital source, and it is safe to say that there are quite a few manufacturers whose efforts of late have included the introduction of high-performance music servers (Bladelius Embla and Burmester 111 among others) to compete within this space.
Patrick -
You wrote in your post yesterday:
"...Renderers must slave themselves to the Servers they can see and operate according to the Server's rules. Naim's Servers on the other hand make multiple streams available to any renderers on the network...."
In my view, operating according to the server's rules (i.e., the central management of options on a single UPnP server on behalf of one or more players) is "handy". Did I misinterpreted your statement? How so?
Maybe I am once again reading too much into one of your posts, but is there any particular reason for your harsh tone? Did I do something to piss you off?
Hook
It doesn't use UPnP though - as far as the player is concerned it is playing music files on a local disc. Using NFS allows you to mount a disk on a server as if it were a local disk. I've always been puzzled why this is not the standard way of doing things and why UPnP was ever necessary (there probably is a reason, but I don't know what it is).
Why couldn't you just have a player with 1GB of RAM free and access a share over NFS and copy the album in to local RAM as soon as the first track was stored you could play - I'm not sure this would be regarded as streaming, but I would think it would sound pretty good assuming the player and it's S/PDIF out were good. However, nobody seems to do it that way so perhaps it isn't such a good idea.
You wouldn't need Windoze, OS X or any other such system to run this type of player - you could put the artwork and other metadata associated with the files on an iPad and use this to control the player. The player itself would run a small AmigaOS kernel or similar - perhaps its software could be written directly for an XMOS CPU and avoid the OS all together.
The player I'm describing is similar in many ways to PS Audio's CD transport except that it gets the files from a network file share rather than local CD.
Allen
It will be interesting to see. When Naim were developing thier top of the range CDPs, they were definitely of the view that sperating DACs from the transport brought more problems that it solved. Technology has moved on and Naim feel quite comfortable to do this now, and we can certainly hear the benefits of thier engineering and product design. Therefore I wonder if an all-in-one high top of the range network player fits with thier new philoosphy. Given the cost of product development I'd be suprised if we saw ND555 or equivalent.
I wonder if the next suge of product development from Naim will be more centred around Class E amplifers, that is the exciting technology area currently that can give great advances in our audiophile world.
Simon
Thank you Jack, for summarizing perfectly my point in few sentences. This is exactly why I propose it would make sense if Naim would offer a HDX version without the ripping engine and possibly also without the dac. (a device analogous to NDX in functionality but using "file sharing" instead of UPnP.
I agree that two setups you describe are functionally equivalent in a single player context, with but minor differences. For example, some of the UPnP server-side options can be handy. Hi Hook, this was one of the answers I was searching when I asked the title question. I also find some of the options of Asset server very handy, like the "File and Foldername browsing" when browsing for different format versions of the same music etc. One advantage of UPnP seem to be the possibility to use different servers with different set of options. However, these options may be built into Server/HDplayers as well. In fact, HDX, UServe, and NS0x family of players all have your "convert to wav" option, as well as my "folder location search" option. ...... And yes, having UPnP set up also allows me to easily share my music library with the Denon AVR in my home theater setup, and, possibly, with a future second stereo I'm thinking about building around my old C7's (maybe with a UnitiQute). And in the model I am proposing the server for your second (and third) zones would be the server/HDplayer in your first zone. So, my proposal would not contradict your multi-zone plans.
... Finally, if Apple's AirPlay takes off, and if, as rumored, the NDX is going to support it, then that should also open up some very interesting possibilities. And again, in that case, the AirPlay would be more significant for the other zones than the first zone.
I surely understand why you are using NDX, as the product I am proposing does not exist yet in the Naim range!
Hook, Aysil
... UPnP...is part of the larger DLNA initiative. ...
Hook
Small correction here: afaik, DLNA is on the contrary a subset of UPnP. DLNA aims to provide interoperability of devices in the home network, and therefore narrows down formats and standards used in UPnP, and neither Naim nor any of the audio manufacturers we discuss often are part of this initiative.
Best regard,
Alamanka,
Storing the data in multiple or single location is not really related to my argument about non-UPnP players. David introduces some ideas on this later in the thread. However, it doesn't matter if data is in single or multiple location, a Server/HDplayer can reach them and render them for playback.
As to your comment, that "data center should come from IT manufacturers", I am not fully convinced about this. This is off the topic of this thread, and I want to bring up and discuss this later in another thread.
The above would free up room in either the HDX or NDX because of no internal PSU taking up a great big chunk of the internal real estate. In my mind this should free up enough room to do special things with the internal DAC (which has to be the equivalent, or better than the nDAC's).
...Simples! ![]()
So what's stopping you Naim?
Allen
Allen,
I certainly share your wish for less box count, but I am not sure if this is practicable especially as you go to a higher range of Naim. Usually, box counts go up as you go up in the product ranges. However, if this will be possible, then I propose a different path. You propose to exclude the ps from the box and thus open space for a superior dac, which would then need no upgrading. I propose the opposite: to exclude the dac from the box of an higher range player, which we both imagine would arrive one day. As we've seen many times in this forum, choice of dac depends a lot on personal taste, as every dac has a different sound characteristic. Free choice of dac should be retained. Moreover, the S/PDIF interface doesn't seem to be a bad interface after all. Naim has avoided it for a long time and now recommending it on its "upgrade" paths. You also reported that the good qualities of the UPnP input of NDX are retained and even upgraded when an external dac was used.
Many manufacturers include the dac in their players as a strategy to keep the customer (and his/her money) for the dac component as well, but I doubt if this strategy is working, as it makes the customer insecure about to what component in the purchased device the money is going.
When you consider all the solutions that have been around in the last 3 years or so (probably longer) and the progression (and sometimes regression) that has occurred, a lot of that alchemy appears to occur in the 'rendering' part just before the signal hits the DAC. I believe this has a very significant effect on the sonic signature of different units or solutions from different hardware ( and software) developers. That's been my overall impression after all this time 'dabbling'. IMO, Naim have hit a 'sweet' spot in this area with the NDX, and it will be interesting to see whether this 'alchemy' in particular is taken forward onto their higher range units.
Allen
Allen,
I totally agree with you on the significance of the sonic signature of the 'rendering/pre-dac-processing' sections. We had discussed abundantly how these differences could originate: Simon had proposed it would be due to DSP and then was not so sure; AMA reminded us of the importance of the quality of S/PDIF generation etc. Whatever! To your remark, that a sweet spot in this area was hit by NDX, I want to add that HDX is also in this sweet spot, imo even slightly better in some respects. That's why, I wanted to question if file sharing method could possibly have some sonic advantages compared to UPnP stream client method.
Hook
Didnt mean to be harsh... I actually read your post and thought it was written by Aysil... Hence my further confusion with what Aysil is trying to do or say.
Sorry buddy!!!!!
Patrick
