I use Audirvana+ in iTunes Integrated mode... I prefer the iTunes interface and don't stream so I'm not too fussed about Tidal integration. I went with it based on forum conclusions to be honest and found it sounded so good I've not felt any real need to trial other stuff.
I was using Integer 1 but couldn't tell any differences in A/B comparisons. However, listening to Integer 2 at the moment it does feel like a slightly more relaxing listen yet I don't really feel like I've lost any transparency or soundstaging as suggested by the Audirvana+ manual.
FYI, I checked my Audio Midi Settings and it says that into Hugo via HD USB port, it is 2ch-32bit Integer.
