NAC 202 product cycle?
Posted by: Nigel 66 on 25 August 2016
Dear Forum
I'm currently thinking about buying a new NAC 202 (savings are almost there), to replace my old and trusty 112x. Just a couple of questions if anyone can help, being:
Does anyone know where the 202 is in it's product cycle? I have a knack of buying electronic goods just as 'new and improved' models are launched, and would prefer to avoid this again if possible. I know some will say that it's a good pre-amp, and as long as you're happy with the sound, etc, then you'll be happy, but it can be a little 'annoying' if within a month or two a new version is released.
And, I can't afford a power supply beyond a napsc - is it worth spending the £350 for one?
Nigel
Posted on: 25 August 2016 by Richard Dane
Nigel, nobody outside of Naim's inner circle knows if or when the current Reference range of pre-amps will be re-vamped, replaced or just retired.  So it's impossible to say where a NAC202 might be in its product life-cycle, but what one can say is that the range has been around for 13 years now so from that you can draw whatever conclusions you like - but chances are they'll be wrong.  Naim are known for not changing things unless there's a good reason to do so - after all, the NAP250 remained fundamentally the same for almost 30 years, and the Hicap has survived over 30 years with the only major change being the recent DR upgrade.
p.s. Yes, the NAPSC is very worthwhile.  Just do the demo.
Posted on: 25 August 2016 by hungryhalibut
Just get a used 202 for £800 and a used napsc for £200 and you are sorted. You'd be potty to spend £1,900 on one.
Posted on: 25 August 2016 by b_lund
Hungryhalibut posted:
TBH Nac 202 is not worth full retail IMO, as suggested purchase used there's lot of them - why ?
because 202 is a revamped Nac 102 which was a scaled down Nac 82, none of these my cup, hard to explain but they just didn't last very long, recently heard the new 5Si, it is much better musically(with less resolution and transparens) than say 102/Nap, main diff between 102 and 202 is the cabinet at least to my ears
I've had them all, happy back with Nac 72 as I can live without remote and love the green stuff, it need not any Napsc which sound very expensive for what it is. - provided it cost what you wrote
Offcourse 202 would be better than a 112 but you never know if they change preamp range this or next year, afterall its 90'ies technology, not that there's anything wrong with that. Have you considered using a Qute as pre meanwhile until dust has settled ?
Posted on: 25 August 2016 by Scooot
Just to add to what HH has said.Purchase second hand and you should get a 202,napsc and hi cap dr for about the same money as a new 202.
Posted on: 25 August 2016 by cyclo
People do move on from 202 but the reason there are so many of them out there is because they are incredibly popular. 202/200 are a very dynamic combo and a bargain used.
Posted on: 25 August 2016 by Antonio1
b_lund posted:
Before the purchase of a vintage 202 I had UQ matched to 200. I had in the past 72/hicap/180 very good too.
I regretted every single moment I played with  UQ into 200.
Nac 202/napsc and possibly hicapDR is definitely the entry point to a great performance. I'd buy it again any day. A Classic.
Posted on: 25 August 2016 by Adam Zielinski
With that budget, try to find a pre-loved 282. Will be more fun, even with NAP200 (actually 282 + 200DR is remarkably enjoyable, even without a HiCap).
Posted on: 26 August 2016 by Bob Edwards
I agree with the suggestion to buy a used 202/NAPSC/Hicap.  Good preamp, and sorted out the challenges the 102 had.
Posted on: 26 August 2016 by DavidDever
Any reason as to why you might not consider a SuperUniti? Better volume control, preamp + power amp sections, with the same DSP as your ND5 XS–and you can eliminate three boxes.
I'd be wary of a volume-potted preamp in the Naim range at this point: Statement shows that the writing is on the wall for that technology, and none of the newest Naim preamp / control products utilize a potentiometer anywhere.
Posted on: 26 August 2016 by Bart
I think that if you have your heart set on an analogue preamp (202, 282) it would be silly not to buy pre-owned.  These things do not wear out.
Posted on: 26 August 2016 by Adam Zielinski
+1 for Bart.
Posted on: 03 September 2016 by Nigel 66
Thanks for the responses, I'll look into the prices of 2nd hand 202/200 units.
One thing though, does anyone have any experience of the SuperNait 2. A little bit more expensive than I wanted but I quite like the idea of reducing the box count a bit. Any thoughts on SQ vs 202/200?
Posted on: 03 September 2016 by Adam Zielinski
Yes
Care to elaborate a little Adam?
Nigel 66 posted:
SN2 is a very good, detailed, fast and musical integrated. From the various tests I've done, if a system is to be based on NAP200, the closest pre-amp to match SN2 would be NAC282. In other words: a bare NAC282 (this already includes NAPSC) and NAP200 sound very similar to SN2.
Adam
Thanks Adam. I might try and demo one - sounds like it'll be a big step up from my current 112x/150x !
Posted on: 03 September 2016 by joe9407
hi Nigel -- i'll add another vote for a secondhand 282/Hicap. should be within budget and is a piece you can build around in the future. i'd keep your current amp and use the flatcap to power your cd player and Stageline.
Posted on: 03 September 2016 by Christopher_M
Adam Zielinski posted:
Really? I'm surprised if that's the case. But I've not done the dem. No need  :-)
C.
Christopher_M posted:
C.
I was surprised too. Not identical (this would be most odd) but similar.  Forgot to mention: SuperNait2 was running with a HiCap DR.
So: bare 282 + 200Dr vs SN2 + HiCap DR.
To my ears - very similar sound signatures, bass weight and prrsentation.
Posted on: 24 September 2016 by Nigel 66
Just thought that I'd post a quick update. After a lot of thought and listening, I decided to reduce my box count a little, so have just ordered a Supernait 2. Got a decent trade in deal, so hoping that in a week or so I will have it in my system.
Have also just got a replacement stylus for my Ortofon 2M black, so that should be properly bedded in by the time the 'Nait 2 arrives, so really looking forward to some proper listening in 7 - 10 days.
Thanks for all the suggestions above, but think this is the right way for me to go at the moment.
Nigel
Posted on: 25 September 2016 by ChrisSU
Nigel 66 posted:
Nigel
Nice......but a Supernait 3 is bound to turn up soon, then what will you do?
Posted on: 25 September 2016 by Nigel 66
Noooooooooooooo ! ! ! !
Posted on: 25 September 2016 by Bob Edwards
Nigel 66 posted:
Nigel
Congrats!  You'll LOVE it!
And your opinion is the only one that matters re the right way forward.
Posted on: 25 September 2016 by Adam Zielinski
Nigel 66 posted:
Nigel
Good choice. It is a seriously good piece of kit.
One advice if I may: I found a PowerLine to be a significant upgrade for my SuperNait2.
