Muso Wired or Wireless
Posted by: Sutts on 26 August 2016
Hi everyone, I'm new to Naim but have been told great things about the people on the forums so here goes! ...
When I first set up my Muso I connected everything wirelessly and ran that for a few days, then I plugged the ethernet cable into both the router and the Muso. It works fine but how would I know if the connection is actually wired or wireless, which one is active? Don't think the LED light gives this away?
I either stream from my MAC (UPNP) - as the MAC is wireless, would the Muso still play at the higher quality rate (presuming that the MUSO is using the ethernet connection that is)? Or limited to 48kHz ?
Most tracks I play through Tidal are Flac 44khz ... 16bit? - I don't have any 24 bit music but what do you guys think, would there be a noticeable difference in sound quality through the Muso? I take it that sort of quality is not available by Tidal - any suggestions where I look for content?
Thanks,
Paul
