Uniqute2 streamer - volume problem
Posted by: Ivan Swales on 27 August 2016
In May i bought a uniquote2 I have a wireless connection to spotify.  Tonight it went mute al by itself and then down to zero volume after i unmuted it.  Also a lot of the time the volume drops to 0 and then back to full volume etc?  Any ideas or do i have a faulty unit  I live in a detatched house so it would not be neighbours remote and my wife had her iphone off  Thank you.
Posted on: 27 August 2016 by Erich
First of all call the ghostbusters.
Extract the batteries from the remote to discard a problem in it.
Posted on: 27 August 2016 by Mike-B
Your first call should be to your dealer,  its still under warranty,  & its been reported before if you search the forum
Second call should be to edit (tidy up) the thread title,  it supposed to be a title line  not the whole story line.
Don't know if your dealer will take the call satuday night.
Posted on: 27 August 2016 by feeling_zen
To eliminate stray IR signals (I had a similar issue with a new UQ2 near a mirror, since moved it has been gremlin free for 2 years), cover the IR sensor by placing some card upagainst the Naim logo and screen. If this cures the gremlin then you'll know placement is the issue. Sunset and sunrise are common times for these issues.
Make sure the protective film is removed from the logo also and touch it a few times to mute on/off to confirm it works. I found the touch sensitive logo needed several manual cycles to work out the inner demon.
And if that fails, power it down and call your dealer on Monday.
Posted on: 28 August 2016 by Richard Dane
I have edited your topic title to something more succinct. Well worth checking out the suggestions above.  Otherwise get in touch with your dealer.  It could be a fault with the touch sensitive logo panel.
Posted on: 15 September 2016 by Dave Finn
Hi, I visited the forum because I'm having the same problem. I bought my Uniqute 2 in June and didn't have any problems, suddenly it's started this volume stuff. Mostly it volume turns down or goes into mute.  Occasionally the volume goes up. I've had to restict the volume level to prevent it going to loud.
I don't think it's the mute button because I can see the display cycling between screens when it happens.
Posted on: 15 September 2016 by Richard Dane
Dave, as above, I suggest you get in touch with your dealer who can investigate.
Posted on: 16 September 2016 by Tamarin
Via the remote control, go to Settings, Display, and set Logo Mute to 'No'. Does the problem still occur? If not, perhaps you have a faulty logo or touch controller chip.
https://forums.naimaudio.com/to...of-its-own-unitiqute
I have these volume gremlins with my UQ2 too, and I'm using Logo Mute=No for now, as the issue doesn't bother me enough to deal with servicing. Especially as I was using the Logo mute/volume control feature very infrequently.
Posted on: 16 September 2016 by Dave Finn
Thanks Tamarin, I contacted my dealer yesterday but it would be interesting to see if that works.
