250DR smile and LP12 grimace
Posted by: Allan Milne on 30 August 2016
As some of you know from other posts, I have been home demoing a 250DR.
Well today it left me to be replaced by a spanking new one
... magnificent from first turn on but I also got the dealer to replace the rollers on the B&W 803D3's with its spikes at last. So that would have helped too.
All smiles playing tunes from my Unitiserv; tight bass, great detail and soundstage , etc etc etc
So then it was time to try it with vinyl on the LP12
... oh dear, it sounds all wrong, must be a bad pressing since I've never played this disc before;
... disaster - its wrong on my other vinyl too
... what to do, who to ask ...
... some of you know I'm blind so I had to wait on the chief executive coming home from ladies who lunch and asked her to look at the cartridge needle
... "yes the needle is ok, just bending out a little - is that a problem?"
... and then the penny dropped, after last playing a disc I had knocked into the Fraim and the arm had come off its catch but other things had distracted me and I hadn't checked it out proper!
Well that is the end of the Klyde and a Krystal is now on order, hoping the home insurance will cover it, seems favourable.
At least I'm able to keep smiling with the noise coming out of the UnitiServ through the new 250DR - did I say it was magnificent?
so the moral of the story is ... hifi just keeps giving and taking and giving and taking and ...
Allan
