Fraim stack order
Posted by: EastEnder on 08 September 2016
I did do a search but didn't come across a thread with this setup:
Fraim (base, 1x 264mm shelf, 2x 115mm shelf)
NAIT XS2, FlatCap XS, ND5XS, Rega TT
What would the recommended stack order be? From what I have gleaned from what I have read, I am guessing:
115mm shelf: Rega TT
115mm shelf: FlatCap XS
264mm shelf: NAIT XS2
Base: ND5XS
But...perhaps the wise on the forum would suggest otherwise?
Posted on: 08 September 2016 by TOBYJUG
I wouldn't think there's much in it , but if it was my system
115mm. TT
115mm. ND5XS
264mm. FlatcapXS
base. NaitXS2
wiring it up round the back will be easier and more tidy.
cheers.
Posted on: 08 September 2016 by David Hendon
Most people seem to put brains at the top and brawn at the bottom.  If you are using NAC A5 then having the amp at the bottom may make things easier, so Tobyjug's suggestion seems logical to me.
best
Posted on: 08 September 2016 by hungryhalibut
I'd have TT, amp, streamer, Flatcap. You want the amp where you can reach the buttons easily.
Posted on: 08 September 2016 by Aric
TT at top, Flatcap on the bottom is my recommendation. Try swapping the Nait and streamer and see if you notice a difference.
