Muso QB volume problem
Posted by: andrew jameson on 25 September 2016
Hope someone here can help me!
I've just connected my Muso QB as per instructions and I'm able to play music via UPnP, Spotify, iRadio and via the USB port ... BUT i can't control the volume level, this seems to be fixed at a low level and increasing the volume via the app or via the volume control on the Muso or by increasing the volume on iPhone makes no difference - Quite frustrating!!
Anyone got any thoughts?
Andy
Posted on: 25 September 2016 by Penarth Blues
Go to audio settings (on the little cog wheel) and check you haven't got a low maximum volume set there. My max volume is set around 65 - which is plenty loud enough for my ears.
Posted on: 25 September 2016 by andrew jameson
Done that it was set to 100 so it must be something else!
Problem solved! Not quite sure how but i rebooted my router, relaunched the app and all seems to be fine!
