Connect NAC 202 to active speakers?
Posted by: board on 27 September 2016
Hi.
I asked on another forum as well, but I figured I also better ask here to make sure:
Can I connect active monitors, such as Yamaha or Mackie studio monitors, to the NAC 202?
I was told that I could do that if I buy a cable that has two XLR or jack connections in one end and one 4 pin DIN connection in the other end.
And then I should plug the DIN end into the "standard" connection on the back of the NAC 202 (where now the NAP 200 is connected).
Do you guys agree this should work?
Moderated Post: Links removed. Please don't post commercial links in the Hifi Corner, thanks.
