nac 202 with nap 300 dr
Posted by: Aceone on 30 September 2016
Hi everyone has anyone heard 202 with a 300 dr  I've just been offered one at a really good price I will be getting a nac 252 in the near future any advice would be much appreciated thanks .
Posted on: 30 September 2016 by The Strat (Fender)
Hi,
No but if you're getting 252 in the near future then go for it but 2 points:
  • You'll need a HCDR or SC as the 250 AND 300 cannot power the 202 like the 200.
  • The 300 will seriously show up the (relative) deficiencies in the 202 - good that it is!
Lindsay
Posted on: 30 September 2016 by Bob Edwards
Go for it!
Do take note of what Lindsay wrote, though.  It will sound great, and any weaknesses will be due to what is upstream; namely, your sources and 202.  With a 252 coming "shortly," jump on the offer if it is that good.  Note that 300s (including DR versions) show up on the used market relatively often.
Posted on: 30 September 2016 by Aceone
Forgot to say my nac 202 is powered by a supercap 2
Than you're in business!!
Posted on: 30 September 2016 by Foot tapper
The Strat provides a perfect summary for you, noting that the power amp will reveal the character of the 202/SC in full.
Best regards, FT
Posted on: 30 September 2016 by Ron Toolsie
While my 52 was off for service, I used a 102 with SC into 6x135 and active DBLs. The 102 was surprisingly capable when juiced with the SC....far, far better than with a Hicap, which I also tried. I seem to recall it was warmer, looser and stripped of some of the dynamics and panache compared to the 52, With a mere Hicap powering it, it was rather dull and insipid and inappropriate to be used with the revealing electronics downstream.
Posted on: 30 September 2016 by Pcd
If a 252 is just around the corner go for it.
Posted on: 30 September 2016 by elkman70
Go for it
Would 300 dr sound better with my 202 for now
Posted on: 30 September 2016 by Chag...
As others have mentioned, if 252/SCDR is really planned to come in the near future, go for this 300DR. It is the ideal companion of the 252. Yes it will sound much better than the 200, already a great amp with its own merits, even with 202.  <:)
Chag -
Posted on: 01 October 2016 by Edouard
Aceone posted:
Well some people like Richard Loyd are very happy with a Dac-V1/300, hence a 202/HC or SC/300 would make at least as much sense
I assume you'll have soon a SC in your system if you planned to go from 202 to 252
BTW you'll be quite surprised when you'll power your 202 with a SC
Edouard
Posted on: 01 October 2016 by Aceone
all ready using a supercap 2 with my 202 and it did make a big difference to the 202
Posted on: 01 October 2016 by ClaudeP
For about 9 months I had a 102/300 combination and it played beautifully. The 102 (or 202) can sound a little edgy at times but in my system the 300 was counterbalancing that very well.
The preamp got upgraded to 252 and 552 afterwards but I had a great time with the 102/300 pairing when I had it.
Claude
Did the 202 replace the 102
Posted on: 02 October 2016 by ClaudeP
Aceone
I think My answer was not very clear, sorry. l never had a 202, my point was that both 102 and 202 can sound a little edgy at times. I upgraded the 102/Hicap/NAPSC to a 252 and now to a 552.
Claude
Posted on: 02 October 2016 by Aceone
Thanks for your answers , I think I will get the 300 dr then the 252. At a later date.
