Very loose mains connection on Superuniti
Posted by: taxbuster on 02 October 2016
I have a SU with a Naim Power-line and the connection is VERY loose. Now the manual says "The metal body of the IEC connector is able to move a little when the Power-line has been inserted into  a mains input socket. This is intentional."
However, it is loose enough that a slight touch dislodges it such that the electrical connection is also broken. I cannot believe this is intentional.
The socket itself is somewhat loose (I believe this is the intentional part) in its housing in the SU, but when the Power-line is connected, the whole thing can wiggle 1 cm or more. This is quite distressing as I'm worried that it can short out. I noticed this recently as I had to move the Fraim/SU to a new location and one of my cats delighted in walking behind it - and cut off my power.
Any thoughts? (other than getting rid of the cats....likely a losing proposition with my DW)
Posted on: 02 October 2016 by Finkfan
Is the powerline pushed in far enough? Every powerline I've connected has made a very firm connection. It may just need to be pushed home a little harder
Posted on: 02 October 2016 by hungryhalibut
It's not in far enough. Hold the fat silver bit (not the black bit), locate it on the pins, and give it a damn good shove. The jaws on the plug will grab the pins in the socket and all will be well.
Posted on: 02 October 2016 by dave marshall
Have a read of this.
https://forums.naimaudio.com/to...s-properly-connected
Posted on: 02 October 2016 by taxbuster
OK - many thanks - you guys are FAST! I was a little nervous as I felt I'd already pushed quite hard but....not so! There was just a little snick more and it seems quite stable - but it really does require a surprising amount of "push"!!
Excellent. Your cat should now be able to swing on the Powerline quite happily.
Purrfect!
Posted on: 02 October 2016 by Richard Dane
The internal jaws of the Powerline are made as tight as regulations allow.  This makes for a very good and secure electrical contact and contributes significantly to the Powerlines excellent performance.
