No sound...
Posted by: Michaudg on 02 October 2016
While I Was listening at low volume, I touched  the remote  (with Was upside down ) I lost the  sound.
Setup: REGA  Saturn. Nap  155sx. Nac 112x, Flat cap DAC classic.
I tryed to reinitiate the remote settings. ...NADA.
I've tryed everything  so far:
-another préamp  (202)
- another CD player
- other  type of connection  (Toslink  instead of RCA  TO DIN)
Any suggestions ?
Desperate
Posted on: 02 October 2016 by sjbabbey
Mute button?
Posted on: 02 October 2016 by Michaudg
No mute. All the lighs are on....tryed with different  connectors and another CD player with and without  the DAC .... puzzled!
Posted on: 02 October 2016 by Finkfan
All connections on the amp OK?
Posted on: 02 October 2016 by Richard Dane
Have your tried different input on the NAC?
Everything  Was unpluged, re-connected everal imes.  We have tryed for several  hours. We've concluded  that the Ampli Was defective. We Brought  it to the dealer.  It Was in perfect order.
Gilles.
Posted on: 02 October 2016 by Frenchnaim
RCA/DIN ? I had no sound from my CDX2 before I realised that it was set for RCA, not DIN. That could happen inadvertently.
Posted on: 02 October 2016 by Frank Abela
Most likely the preamp. With no music playing, turn up the volume. Is there an increase in hiss? If there is no hiss, then nothing is coming from the 112x.
Also, the 112 had a gain adjustment per input so you could adjust relative volume levels of different sources. It's possible this could have been changed? Check the manual and do a factory reset on it.
Frank.
