nac 202 +ndx or nac 272
Posted by: Adi Stefan on 03 October 2016
Need advice, I have 200dr power amp, and nd5xs, focal electra 1028. Whats best way to go, update nd5xs to ndx or change nac202 + nd5xs to 272, and later, but later, 250dr.
Thank you.
Posted on: 03 October 2016 by ChrisSU
I thought NDX/202 was clearly better than a 272. In fact, I thought NDX/202/200DR was better than 272/250DR, despite the superiority of the latter power amp. You need an XPS on the 272 to make it a contender. Having said that, your speakers may be more demanding than mine, so maybe the 250 would be a higher priority for you?
Posted on: 03 October 2016 by feeling_zen
ChrisSU posted:
I thought NDX/202 was clearly better than a 272. In fact, I thought NDX/202/200DR was better than 272/250DR, despite the superiority go the latter power amp. You need an XPS on the 272 to make it a contender. Having said that, your speakers may be more demanding than mine, so maybe the 250 would be a higher priority for you?
Ssshh. A hungry fish might hear you and rip you a new one for saying that.
feeling_zen posted:
ChrisSU posted:
That sounds exciting?!?
Posted on: 03 October 2016 by Adam Zielinski
I would ask a different question: do you want only few boxes (in that case N272 is a good solution) or if you don't mind few more black boxes (in that case a separate streamer and a pre will be avisable due to upgrade flexibility).
Adam
PS Heard a sound of a flat fish moving in the dark waters nearby...
Posted on: 03 October 2016 by The Strat (Fender)
You have to decide based on audition and how much you wish to spend and perhaps what your future plans might be with regard to upgrading - a separate pre would give you more flexibility.  But in my opinion an XPS is very highly recommended on both the NDX and 272.
Lindsay
Posted on: 03 October 2016 by Pcd
Agree with Adam how many boxes do you want/need suggest a discussion with your dealer and demo's as required also bear in mind the more boxes the greater the cost of getting the best out of them ie Power Lines , Equipment Rack better cables etc etc
Posted on: 03 October 2016 by Emre
272 is a better value as well....  i changed my 200s + ND5xs for 272....
Posted on: 03 October 2016 by Bob Edwards
202/NDX will sound better and provides easier upgrade path.
Emre - value is a personal judgement.
Posted on: 03 October 2016 by Antonio1
Keep your preamp and upgrade to NDX, or just add nDAC.
What you have is already better than 272 .
The Strat (Fender) posted:
No I meant cheaper, same price as ndx you get the pre gratis
Posted on: 03 October 2016 by nickpeacock
I worked my way up from Uniti/200 to ND5/282/HC/250 to NDX/252/SCDR/250DR. Great leaps forward every time. Where I'm at is magical.
272/XPSDR/250DR has many respected admirers, and one less box.
So: (i) decide on your budget; (ii) check where you might want to end up in a few years' time and (iii) bear in mind the box count; (iv) audition if you can. Both your suggestions have lots of good points.
That's my point - what represents value is a judgement but the cheapest is absolute.
Posted on: 03 October 2016 by fenderized
Are we counting boxes here....or is it about wfm..or sq...????
If it's about boxes or wfm..then it must be a Unitilite..or... even a UQ...right..????
Now...what was the OP about..??? Almost forgott....
Posted on: 03 October 2016 by Chag...
Wait until Thursday before making any decision. Who knows..  :]
Chag -
So true...after Thursday...combos like 272/250DR e.t.c. will be soooo obsolete and feel soooo 2015. Who remembers them...???
Posted on: 04 October 2016 by Adi Stefan
Than you all for sharing your knowledges and experience, i ve read with interes all opinions but decision is mine, I ve ordered ndx...later i will go with 282/250, but later . Hope tuesday naim will not blow the hi fi world.
Posted on: 04 October 2016 by Pcd
Hope you enjoy your NDX as much as I enjoy mine lovely piece of kit.
Posted on: 04 October 2016 by Antonio1
hi, Aid great choice.
No need to worry about 06/10 ,you've already avoided a much worse move keeping the 202.
