Hello all,
my nap 150 is 12 years old and, according to "Naim rules", it needs (maybe) a servicing.
Since it's possible to find s/h nap 155xs, what do you suggest, a nap 150x serviced or a nap155xs?
putting aside the aesthetic valuation, what are the sonic differences?
thank you in advance,
regards
Posted on: 03 October 2016 by airdavid
thank you Hastings.
Sorry, yes I have a Nap 150x matched with Nac 122x.
so, do you suggest to maintain the original 122x-150x combo?
Posted on: 10 October 2016 by airdavid
Hastings, Bob and Hungryhalibut,
do you suggest also the same for my flatcap 2x?
Putting aside the aesthetic valuation, is it better (and cheaper) a serviced Flatcap 2x than a Flatcap XS ?
Posted on: 10 October 2016 by Bob Edwards
David -
The problem is simply one of value. You can buy a used Hicap DR for about $1100 USD; this will far outperform any Flatcap. It makes more sense to me to buy a used Hicap DR and then sell off the Flatcap 2x - you'll end up spending perhaps $100-200 more than servicing the Flatcap, and have a significantly better system.
