Upgrade my UQ2 / NAP100 combo
Posted by: Chico on 05 October 2016
Hello fellow Naim users,
I'm really in need for a new washingmachine, and my laptop is getting old too..
But.. i decided to upgrade my hifi first
Currently i have a Unitiqute 2 with a NAP 100 and a pair of Tannoy DC8's.
For me the dream is a superuniti, but these are still a bit expensive, so i was thinking about
a s/h NAP250.2 or a new NAP200dr.. the NAP250's are getting reasonable in price, and i could
have it upgraded to dr spec's later.
What you think ?
Greetings from Holland.
Posted on: 05 October 2016 by Antonio1
hi  my two cents.
UQ2/100 bad idea (I had) adding 200 (I did ) makes much more sense.
But selling UQ2 and budgeting the purchase of a 200DR would help get you a SU instead..
That would be the best move.
Posted on: 05 October 2016 by Chico
Yes thats an option also, selling UQ2/NAP100 and buy secondhand superuniti...
Should think about that, thanks Antonio
you're welcome.
Posted on: 05 October 2016 by ChrisSU
If you get a 200, remember that the DR power supply is only for a Naim preamp if you use one, which it seems you are not planning to do. So a used non-DR 200 would be much better value, maybe only half the cost, and you could sell your 100.
Then you could look out for a 172 and sell your Unitiqute. 172/200 is a nice setup, probably better than a Superuniti.
Posted on: 05 October 2016 by feeling_zen
ChrisSU posted:
Absolutely agree.
I have a UQ2 and it is stellar but if I had a a UQ2/100 combo the most logical solution would be a 172 or even a 272 if funds allow after selling the UQ2. The 100 is small but perfectly formed. If it drives the speakers well then focus on source and pre.
Posted on: 06 October 2016 by hungryhalibut
I would get a non dr 200 used, and then  save up for a 272. If your Tannoys are the £2,500 standmounts, they deserve that sort of system.
Posted on: 06 October 2016 by Chico
Thanks for the info guys, much appriciated.
Loads of options as it seems.. and now a whole new line of unitis... gonna eat beans for some months i guess
Posted on: 06 October 2016 by Simoncarr
Hi. I upgraded my UQ2/100 combo to a 172/200 combo. I bought the 172 new but purchased a second hand 200 and I love the combination. It was a big upgrade in sound over the UQ2/100 combo. More bass, more soundstage and just filled the room full of music. I using it with Kudos X2 speakers and my LP12.
Posted on: 06 October 2016 by Kermit
Depending on size of room/efficiency of speakers, sell the 100 and just use the Qute (better than a SuperUniti) IMO!
Interessting Kermit, never tried my DC8 standmounts without the qute / nap100 combo as i bought the speakers
later. To me it seems that the qute/nap combo lacks something.. especially in the midrange, sounds a bit dark or smotherd or something.
So i guessed i need some more power.
Thanks for the replie anyway, greetings from Holland
Posted on: 05 November 2016 by KenRose
Kermit posted:
Kermit, did you not buy a SuperUniti?
