Mains isolating transformer
Posted by: Richieroo on 07 October 2016
Hi I do get some quite loud transformer hum from time to time.........has anybody tried Airlink?
Moderated Post:  Link Removed.  Please don't post unauthorised commercial links in the Hfi Corner.  Thanks.
Posted on: 07 October 2016 by Ron Toolsie
I used a largish (10kVA) balance power isolation transformer with my active DBL system...not only was ALL transformer noise banished (6 power amps, one preamp supply, one Snaxo supply, one CD power supply, one tuner power supply, one Prefix supply and one Armageddon) , but the system sounded very much the better too. A greater than component-level upgrade for less than component level pricing (well, it was $2500 back around 2004...its around $8k now). BUT it is not a plug in option- two ground spikes have to be undertaken and it needs to be professionally wired in to a 50A double voltage feed. But then again, I've seen people who spend longer rebuilding a Fraim than it took for two electricians to have this 200-lb box plumbed in.
This particular transformer was made by EquiTech-who mainly do pro-studio transformers. BTW I had sockets that also had non-balanced power, so it was trivial to swap back and forth. The improvements were immediately obvious to even a casual listener. There are a few threads about our collective experiences here-the first person to use one with a Naim system also pioneered the first XPS2T.
Posted on: 07 October 2016 by Foot tapper
Hi Richieroo,
I started a thread in May 2015 about this.  The Search function should help you find it.
Best regards, FT
Posted on: 10 October 2016 by Richieroo
Hi sorry tried searching - got a tone of posts.... to look at some of them quite technical....can you send me a heading line so I can find post....
Posted on: 10 October 2016 by Foot tapper
Try searching for:
Suffering from those transformer hum blues?
