Brundy cable enigma
Posted by: Emre on 08 October 2016
while i am waiting my new brundy cable i been given an extra one from my dealer that have been used with a NDS
first i had a cable marked red / green which connected to my 272/555 but no sound!
then next day i had a cable marked with 2 green lines which i did not succed to install
anyone can help me with this?
Posted on: 08 October 2016 by Richard Dane
You must only ever connect your 272 and 555PS with an XPS or Prfereably an S-XPS Burndy. Nothing else.
Posted on: 08 October 2016 by Emre
Which one is xps brundy ? Which one is s-xps?
I have tried green and red line one while 272 working no sound
now 2 green line one is not fit i guess.
i there a way to now which one is which? I did bot know that there is xps/s-xps brundy, i have one in order dont even know which one
Posted on: 08 October 2016 by hungryhalibut
If it's an XPS Burndy (not brundy) it will say XPS at the end that goes into the 272. An S-XPS Burndy is the current version and will say S-XPS.
Thank you very kind, Any idea about signs on the cable? 2 green vs paces red and green? I am trying to figure out with these nds cables that I barrowed
The NDS uses the 555A and 555D cables. The 272 needs an S-XPS cable.
Then need to wait for my new one then, many thanks
Posted on: 09 October 2016 by Simon-in-Suffolk
Hungryhalibut posted:
Although I think I am right in saying the '555A' is the same as the S-XPS. (Apart from the plastic cover over the cable itself) I am sure I have used them interchangeably ... but can't check as I have now sold my 555PS and XPS2, but it sounds like your Dealer knows this anyway. Just ensure, like all Burndy cables you insert them into the sockets by holding the cable and not the plastic connector.. (it stops twist and strain internally and improves performance)  Takes a little getting used to, just give yourself plenty of space to work in...
