Dedicated spur and power regen
Posted by: rainsoothe on 13 October 2016
Hi. So, can I have one of these made in an apartment building? An electrician I asked said that there's no point in building a dedicated spur, since usually in apartments the electricity uses 2 wires that come into the apartment (instead of 3) - he also had names for the type of network/grid or whatever, but I can't recall.
So, is there a point of adding a separate mains spur into my flat? (can't put the wires in the wall) Or should I get a mains regenerator instead - or balanced regenerator instead? I know Naim hates power conditioners.
Also thinking about getting a Hydra.
If I added a power regenerator, what specs should it have? - system comprises of Nac N172XS + Nap200, Audio Technica LP5 tt and, in the future, a Yakin tube phono stage.
Also, how should I plug these? As in is it ok to have the tt (+phono stage) plugged in the same spur etc etc - how would you set it up?
Posted on: 13 October 2016 by Adam Zielinski
Yes - it is worth it.
No - don't use the regenerator
Yes - do get a hydra. But even better - get your sparky to install a lot of sockets for your Naim boxes.
Posted on: 13 October 2016 by rainsoothe
Thanks. And another one: should I use the Hydra with the Naims only, or is it ok to get a 4headed beast to plug into my TT and phono as well?
Generally it is better to keep your Naim gear on a separate circuit to the rest of your audio. That includes a turntable too.
Unless.... you start running into ground-loop problems, you may try to use the same circuit.
Posted on: 14 October 2016 by Emre
What is Hydra?  Multi cables one Socket? I am installing 3 separate lines with 3 separate fuses for 3 duplex next year June I hope
Posted on: 14 October 2016 by ChrisSU
Emre posted:
If you do an online search for 'Grahams Hydra' you'll see what it is. Grahams is a London based dealer, and it's a single plug with, as the name suggests, multiple leads branching from it.
