Please, please, please, please, I am begging you please...
Get your shit together on streaming software and firmware. You are freaking horrible at it. I thought my employer made the worst software, but you are vying for the top spot.
The Android app finally was updated to work with Nougat (sort of, appears to depend on some kind of biorhythm/moon phase confluence) and then tonight I have been f***ing with the 272 for half an hour and unable to get past the first 3-10 seconds of the first track.
NEVER is it a case of sit down, select a track, and listen. Best I can hope for is press the "center" button on the Naim remote (twice, once to wake it up, then again to get it to find the network which it says does not exist (No Network - then Please Wait) - on a good day I can then use the Naim app to start playing (always with a few seconds of the spinning wheel of death). Then it will work just fine...and you can't help but wonder why it can't get that result all the time (although the start up process I have described is ridiculous.)
Other days like today, I cannot listen to music, then after f***ing with it for a 20 minutes to a half hour, I get so pissed off I no longer want to listen to music. (But now I am pretty familiar with the first 5 or so seconds of Hey, Hey, My, My, so I guess that's something to be thrilled about.)
Often the remote app claims "Another app connected" - what f***ing other app? There is is no other app - I think the Naim app can't get out of its own way. Then it finally gets to "naim isn't responding" and you can close it, or it appears to find the UPnP, then go through the same bullshit all over again. SPinning wheel of death, then crashes. But now even working from the Naim remote isn't getting it done.
I have rebooted the server, restarted the router, restarted the 272, and nothing seems to work...including using the 272 remote itself. It keeps losing the network and cannot function.
Yet...
There are 4 other computers, a work computer that uses the network for VPN, a DVD player, a TV, and another music streamer, all which work flawlessly and without incident. (No they are not all on at once - but they could be and they'd all work.)
I am sure that many of you are not experiencing these issues. I am happy for you (really, I am, because I wouldn't wish this on any music lover). And I am sure my s**t AT&T router is not the best thing in the world. But as I indicated, there are 6 other devices that are able to use the same router/network without issue, or very rarely an issue. Only the expensive stuff (that's you Naim) can't hang.
Please read that paragraph again - because it is not like other devices (or even other visiting iPads/phones, laptops) ever have a problem connecting.
I would do better to use the SBT and get a pre-amp...what a f***ing joke. (But for some reason I don't much feel like laughing.) I got a great deal on this combo, but if you cannot listen when you want to it is not such a great deal.
Unacceptable. Completely unacceptable.
If anyone has any ideas why ONLY this stuff doesn't work, by all means share. And then others can rip me a new one for blaspheming their religion.
Posted on: 14 October 2016 by DrMark
Just messed with it for another half hour - best I got was about 20 seconds of music before "Stopped - Press Play to Start" and then you press Start on the Naim remote and it finds the last song it was playing, then plays a few seconds: lather, rinse, repeat.
An overpriced door stop at present.
Actually it is a good thing it is costly, because were it not, it might have already gotten hurled into the back yard at this point, as pissed off as I am. I have more than enough bullshit in my life; music and my system are supposed to function as an escape, not a contributor.
Guess if I want music, I have to use the SBT on the backup system - which should be an embarrassment to Naim that such is the case.
Posted on: 15 October 2016 by DrMark
Thanks to everyone who has posted (I just got up and tried - still can't get more than 20 seconds of music.) And I thank the forum that no one jumped on me with both feet for criticizing Naim - part of the reason I do is because having owned many Naim boxes through the years (about half new, half 2nd hand) I have come to (a) expect top level product from Naim, and (b) know their reputation for caring about the customer experience.
Were this another brand, I would likely just ditch the damn thing and be done with it.
Some points to factor in:
1) I would LOVE to get a different router, but with AT&T U-Verse, this is the only one that can be used (and that they can charge me $7.95 a month for...pricks). And I would even consider switching providers, but with a potential move overseas in the offing, and my only other option being Time-Warner (been there, done that, got the t-shirt) it's just a case of swapping one horrid company for another.
2) The router and Vortexbox are way over on the other side of the house in a spare bedroom - probably only about 25 linear feet, but I would need about 50 foot of any cable to get to it...so I will hold off on that option, but it is a possibility if needed.
3) There was a Nougat upgrade that came in for the Nexus phone I use 2 days ago - I read carefully the alleged scope of the upgrade (which was small and quick) and it claimed to be limited to "security and bug fixes." However, as detailed, the 272 no longer even works with just using the Naim remote. (Is it possible that the app could be interfering "uninvited"?) Prior to the upgrade is was working reasonably (if not annoyingly) well...i.e., I could make it work, but the fact that the default state of the 272 when you go to use it is "No Network" is a suspicious thing to me.
4) I actually have an old iPhone 4S - back a month or so ago when I first got bit with upgrading to Nougat, Simon-In-Suffolk had recommended getting an iPad or old phone to use as a remote, and I remembered that I had it - went to install the Naim app and there isn't enough room (I have a s**tload of music on it) - so getting that sufficiently "cleaned up" has been a project to be done in all this, but finding the time has been at issue. Once Naim got the Android app working to even some degree the imperative had diminished. (Plus a trip to Italy and then NY, so there was a period where I was only home 4 of 18 days.) Now I have my employer asking (demanding) a lot of time so I can dig my own grave like a concentration camp victim, so some offshore resource can shoot me in the back and let me fall in...so time for this nonsense is at a premium. (Plus my second job is very busy this month as well with 14 ice hockey games to officiate...oh my aching back.)
5) I am going to read Huge's post a few times and try to log in to the router and see what I see - maybe I can post a screen shot. I am not strong in that area at all. I am also not adverse to someone seeing something in the setup and saying "Oh you nitwit, it is X, just change it to Y!" All I want to do it listen to music.
6) The 272 sees both LMS and the DLNA server - it has been that way since I got it, and for the most part it has worked - is there any issue in this. I mean, they reside on the same box, but of course are essentially 2 different servers using the same hardware.
All this notwithstanding, for all the litany of things Naim does well (and I think we all agree that they do) this software/firmware thing is a pretty big Achilles heel for their product line. I see enough posts complaining and having issues with it that it is clearly not where it should be, especially inasmuch as other company's products are not experiencing the same level of angst inducing behavior.
I hate that this current system is making me miss the SBT + SN combo.
