Uniti 2 alarm function
Posted by: GregWPGibbs on 17 October 2016
probably a daft question, but is there any way to stop my Uniti 2 "Muting"  30 minutes after alarm activation?
Posted on: 17 October 2016 by David Hendon
Clearly no-one here knows the answer to this question! I can't see an answer in the reference manual, not can I see how this might be changed in setup in one of my streamers which runs the same firmware as the Uniti2, but I suggest you email Naim customer support on support@naimaudio.com and they will tell you if there is a way.
best
Posted on: 20 October 2016 by tigersclaw
Try to live with it.  I believe this has been mentioned several times years ago.  Yet the Naim staff just refused to make any change.
