PowerLine Lite
Posted by: Pauleb on 20 October 2016
It would appear the PowerLine Lite is now available although I'm surprised to see the conductors are 0.75mm which strikes me as somewhat light?
Posted on: 20 October 2016 by Finkfan
Isn't that the same size conductors as the standard mains cable?
Posted on: 20 October 2016 by Pauleb
I think your right.
I was anticipating something between the PowerLine and the standard cable.
I can't find it available anywhere so I can't find details or pics. I guess it has the same style powerline plugs?
It's on the Stone Audio twitter feed
Thanks I'll take a look
Well it does look like a lite version of the powerline 13A plug and the standard mains cable with standard iec.
Posted on: 20 October 2016 by Mike-B
Oh dear,  bog standard 0.75mm with moulded IEC,  except for the Naim looking 13 amp plug its very much like a standard issue Naim cable  ..............  but I expect they will get snapped up
Posted on: 20 October 2016 by Clive B
But I'm sure tea will taste better when the water is boiled in a kettle employing a PowerLine Lite mains cable ��
Posted on: 20 October 2016 by rjstaines
Clive B posted:
It's an indisputable fact with the regular powerline...  I've read it somewhere on the forum.
Posted on: 20 October 2016 by hungryhalibut
I've just had some Earl Grey from a Statement mug.
Maybe the lite is for de caf?
Mike-B posted:
I believe they are being supplied 'free' with the equipment though, so it has to be a positive surely.
Posted on: 20 October 2016 by james n
Maybe they'll make a figure 8 version for the Qb
That's a thought. I use an AudioQuest NRG cable on mine.
Nice improvement over the standard cable?
Hungryhalibut posted:
Mike-B posted:
Yes its positive with the Naim 13a plug included in the kit, but a far east moulded IEC on 0.75mm PVC is disappointing.
Finkfan posted:
A little better. It only cost me twenty quid instead of the full price which was two or three times that. The Qb has a posh ethernet cable too, but only because it was going spare. One must treat one's Qb nicely.
I haven't got into streaming properly yet. Spotify on the iPhone is about it. But I do like the Qb. I have my eye on a corner in the kitchen for one.
Posted on: 20 October 2016 by Claus-Thoegersen
rjstaines posted:
Clive B posted:
After 5 weeks without coffee I am of the opinion that  tea cannot be bettered by any device unfortunately. It is close to garbage in garbage out.
Posted on: 20 October 2016 by Drewy
So what's so special about it then? I thought the iec was the special part of the powerline but this thing is just a normal standard mains cable with a fancy looking mains plug.
Posted on: 20 October 2016 by HiFiman
The world has gone mad £100 for the powerline lite !!! It looks like a standard IEC lead with a fancy £10 plug top.....
Posted on: 20 October 2016 by dayjay
I've had enough problems explaining daft cable prices to Mrs DayJay in the past but at least they looked expensive.  If I paid £100 and brought that home I suspect she'd divorce me, or make me listen to Whitesnake, whichever is worse.
Posted on: 20 October 2016 by robert-
Maybe it should of cost £35 and not £100.
Posted on: 20 October 2016 by Timbo
Looks like a bit of a con to me for 100 quid!!
