streaming itunes with Asset
Posted by: zombywoof on 29 October 2016
hi, can anyone help with my imac. itunes issue
i am using Asset as the UPNP with my unitilite light 2 and after reading another thread i purchased the Export Playlist app, set that up as instructed and the export playlist app shows that its has grabbed the itunes library
The Asset has the Export Playlist added but going through the Naim app none of the library appears.
Is it a case that Asset doesn't work with ITUNES
thanks
Posted on: 29 October 2016 by blythe
Asset simply reads the music files stored on your computer (or NAS) and presents them as playable files. Therefore, as far as I know, your iTunes library, on your computer, will work with Asset.
As I've never used playlists, I don't know about exporting them.
Posted on: 30 October 2016 by zombywoof
thanks for the response.
what you say is logical but it's apple!!.
asset reads the cd's i ripped into a music folder beautifully but won't read itunes
Posted on: 30 October 2016 by blythe
Have you actually "pointed" Asset at the folder where your iTunes library is stored on your computer?
I'm not currently with my NAS which has Asset installed, so I can't have a look to see how it's configured, nor can I recall how to configure it off hand.
Posted on: 30 October 2016 by ChrisSU
If you point Asset at the folder where you keep your music, it should be able to see it. This has nothing to do with iTunes, even if you have used iTunes to rip, download or play this music in the past. Just point Asset at the folder, and you should be in business.
Posted on: 30 October 2016 by hungryhalibut
All mine says is /share/Music/
Posted on: 31 October 2016 by zombywoof
thanks to everyone for the helpful comments, it's been sorted
thanks again
