this could be cool for Naim and roon fanboys:-)
Posted by: T38.45 on 08 November 2016
Sonore (yes...the hugo of streaming ;-) ) plans to use roon with upnp devices....they will act like a proxy receiving data from roon server, acting like a roon "endpoint" and translate this to upnp. Here is what they say in the room forum:
This service allow you to "Roonify" your DLNA/UPNP devices. This allows you to use Roon or Roon / Tidal to stream to DLNA/UPNP devices.
AVAILABILITY
Coming soon - You will be able to install and uninstall the service from the unit's Software Manager
The Sonore UPNP Bridge service will be made available on the following hardware:
Sonicorbiter SE, MicroRendu, and sonicTransporter series
COMPATIBILITY
Here is a list of confirmed, plausible, and busted DLNA/UPNP devices.
1. Sonore Rendu (confirmed)
2. Sonore Signature Series Rendu (confirmed)
3. Empirical Audio Interchange (confirmed)
4. MSB DACs with the DLNA/UPNP network input module (confirmed)
5. Bel Canto DLNA/UPNP capable devices (confirmed)
6. PS Audio PerfectWave DAC MKI with Bridge 1 (plausible)
7. PS Audio PerfectWave DAC MKll with Bridge 1 (plausible)
8. Naim DLNA/UPNP capable devices (plausible)
9. Linn DLNA/UPNP capable devices (plausible)
10. Auralic Aries Mini (plausible)
11. XBOX One (confirmed)
12. 4th generation Apple TV with 8PLayer app (busted, but being investigated)
13. DLNA/UPNP capable receivers and processors (plausible)
 >> look at 8 :-)
Ralf
Posted on: 08 November 2016 by simes_pep
Yes, but it does involve a further device in the chain between Roon Core and the Naim player.
Plus given that Roon is build as a Push technology from Core to Endpoint, where UPnP is a Request/Serve model, not sure how this going to work, plus at present what is the advantage?
Now if there was MQA playback on the Roon Endpoint, with a software based decoding of the MQA format, with a UPnP integration to an existing Network Player, that could be interesting.
Simon.
