NAC152XS with old Flatcap
Posted by: Sister Ray on 24 November 2016
Apart from purist philosophical concerns is there any reason why a NAC152XS cannot be used with a serviced original Flatcap?
Posted on: 24 November 2016 by hungryhalibut
I believe the original Flatcap has only one output, whereas the 152 can take two. The Fc 2x is probably the one to go for if you don't want the latest one, as both its outputs are the same.
Posted on: 24 November 2016 by Richard Dane
Just to expand on Nigel's post above, the original Flatcap has a single dual-rail 24V output.  The Flatcap2 has one dual-rail 24V and one dual-rail 22V output (optimised for the CD5, apparently).  The Flatcap 2x and 2xs both have two dual-rail 24V outputs.
You can use any of them with the NAC152xs but only the Flatcap2 (would need confirmation from Naim on whether the 22v is ok here), Flatcap2x and Flatcap2xs can be fully utilised with both supplies used.
Posted on: 24 November 2016 by Sister Ray
Much appreciated HH and Richard.
Posted on: 24 November 2016 by Christopher_M
When was the original FC last serviced?
C.
Posted on: 25 November 2016 by Sister Ray
Hi Chris,
The FC had its smoothing capacitor and tants replaced approximately 6 months ago.
Posted on: 25 November 2016 by Christopher_M
^    Perfect. Good to go.
C.
