Cleaning cd-lens with Q-tip and alcohol - Good or bad?
Posted by: kowalski on 04 December 2016
My Naim CD5 player has the mechanism CDM9/VAM1205.
I made the mistake by cleaning my cd-lens with a Q-tip and T-red alcohol = methylated spirits, I don't know if this is the correct term for this technical alcohol, alcohol is red colored smelling like crap giving you strong headache if exposed to it's smell! T-red is used for removing adhesive residue on metal panels like stereos and other stuff.
I wonder if cd-lens cover is made of glass or is it made of plastic material?
I took a Q-tip and dipped the cotton in T-red alcohol and gently cleaned my cd-lens, this was done long time ago. Maybe this was not a good idea to do? I had playback problems before I cleaned the cd-lens, when I listened to cd's laser would skip a few seconds in some of the track songs, I could hear the interruption when it skipped so I decided to clean the lens with a Q-tip and T-red alcohol . I was lucky not to break or misalign anything. Did I make a mistake byusing methylated spirits cleaning the cd-lens?
