HDX web display
Posted by: R2 on 08 December 2016
Similar issues I guess, but in my case new browser updates have removed ability to use my HDX via the PC. Using FireFox or Chrome browsers just reports [Plugin Not Supported]. I have tried to install Flash Player extensions and even temporarily disabling all the security warnings (usually a very silly thing) but nothing helps. Is there a Naim plugin that will work with either of my browsers? Thanks.
