No sound from Blueray via Optical on new Uniticute 2
Posted by: nomoretechnics on 10 December 2016
Hi - Newby here, I have recently bought a Uniticute 2 and everything is working well. I have it hooked up to a pair of Dynaudio Emit M20s and the sound is amazing!
I recently connected my Panasonic BR player via an Optical cable to the Optical Digital in on the Uniticute and immediately the speakers began to produce a hi speed clicking noise. I cant get any sound to play when watching DVDs and have adjusted the PCM settings on the player. I can play CDs and that seems to work fine. I assume there is not fault with the Naim so it must be the BR player or something I have missed in the settings. I have tried different cables and so can also eliminate this as a possible cause.
Any advice is greatly appreciated!
Posted on: 10 December 2016 by Finkfan
Not sure which player you have but you may need to switch on pcm down conversion and switch the down mix to stereo
Posted on: 10 December 2016 by Adam Zielinski
Set the downsampling  in your player to 2-channel stereo PCM.
What you are hearing is DTS /  Dolby surround sound output in native resolution. UnitoQute will not handle the decoding of such files as it's not designed to do so.
Posted on: 10 December 2016 by Penarth Blues
You may prefer to connect an optical out from your TV to the UQ instead. This works really well with the Uniti2 that I have.
Posted on: 10 December 2016 by nomoretechnics
All sorted cheers chaps!
