Can't get acces to naim app?
Posted by: Muntic0re on 14 December 2016
I don't know why it occurs some error all the time. Only with VPN service everything is working fine. Does enyone know what is going on?
Appreciate for any suggestion.
Posted on: 14 December 2016 by hungryhalibut
You are going to need to be much more specific before anyone can advise.
Posted on: 14 December 2016 by Claus-Thoegersen
iOS or Android. If Android and you are running v 7 I forget what silly name is in use for that, you cannot run the app currently.
Posted on: 14 December 2016 by Pcd
See Naim App post
Posted on: 14 December 2016 by Adam Zielinski
I suspect the OP is trying to download the app.... (wild guess...)
Posted on: 15 December 2016 by Pcd
Android app back up and running.
